10 lug talk - Ford Powerstroke Diesel Forum
 4Likes
post #1 of 97 Old 04-08-2014, 09:45 PM Thread Starter
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
10 lug talk
Figured I'd start a thread souly for the intent and knowledge of running semi wheels on our duallies, I've had them with steel wheels and now have alcoas to run but just wondering where everyone got the wheels, sizes, adapters, tires, how's the ride lifted lowered, mud and street let's go guys
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #2 of 97 Old 04-14-2014, 07:28 PM Thread Starter
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Anyone running all terrains or mud terrain tires on milled 22.5 or 24.5's? Anyone have a tire recommendation? I'm looking to bring my Dually up a bit but want a good tire with some meat for those massive wheels I'm installing here soon, thanks in advance
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #3 of 97 Old 05-14-2014, 10:22 AM
Smitty02's Avatar
Quoted: 15 Post(s)
Man these dually threads don't get much love............
Here are my 10 lugs.....................Stock wheels that came on my f550
2006 F550 Lariat Superduty
Link UltraRide System
4.88 Rear Gear
Banks Big Hoss Bundle
Banks intake
Banks Intercooler
Diesel tech "Bullet Proof" kit
Bullet proof EGR cooler
BPD External Oil Cooler system
Coolant filter bybass system
ARP head studs
40gal aft axle fuel tank
50gal TransFlow/Took box
Rhino lined bed
24K Air Safe 5th Wheel hitch
19.5 Alcoas with 225/70/19.5s
SCT SF3 3015 Tuner
Edge Evolution CTS w/EGT
4" Turbo Back Silverline Exhaust, 5"tip
Smitty02 is offline
post #4 of 97 Old 05-14-2014, 12:06 PM
Quoted: 3 Post(s)
Love em on my truck, everyone hates on them (wear parts out faster, ride like crap...) my truck rode like crap before with stock 16's and still rides like crap with the 22.5's, now it just looks better!
2000 DRW CC 7.3
Exterior: 08 Exterior Clone, 22.5's
Engine Mods: GTP38R WW2, 5 inch exhaust,T500, 6637, TW tunes,DI Up pipes, 6.7 fuel pump fuel system.
Trans Mods: 6.0 trans cooler, JW Valve body,Billet triple disc converter.
Sound Mods: 7" flip out tv, 3-way speakers all around, 12" sub, 500 watt amp.
Misc:dieselsite coolant filter, max ac assist, BRV, IHD,gauges, CCV
Next up power rear window
campbellflage is offline
post #5 of 97 Old 05-19-2014, 02:29 PM Thread Starter
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Mine actually rides pretty good with 16's but I'm stock 2wd coil sprung those 19.5's look good tho, but I'm going with the 22's and low pro' till I lift and convert it and find tires
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #6 of 97 Old 05-20-2014, 06:08 AM
Smitty02's Avatar
Quoted: 15 Post(s)
I have seen a few with the 22"s and they do look sweet. As long as the lower Load range is adequate you are good to go. I'm sure the load E that some 22"s have would of worked for me, I just chose to go with what was on it and stuck with 19.5 load G Continentals. I only run 90psi in them which is only 10 more than a load E...
4.88 Rear Gear
Banks intake
Banks Intercooler
ARP head studs
Rhino lined bed
SCT SF3 3015 Tuner
Smitty02 is offline
post #7 of 97 Old 05-20-2014, 10:03 AM Thread Starter
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
They have load ranges that fit my needs, I rarely haul at my max, which is 20k so with decent tires x 4 on the rear I should be pretty fine, I think I have some nitto420s tires in a 22 laying around anyway they should be well enough to gross mine out if needed
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #8 of 97 Old 06-02-2014, 06:36 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
what kind of a lift would you have to run to clear something like these on a 05?
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #9 of 97 Old 06-02-2014, 06:51 PM
Doesn't Even Care
HVAC SuperTech's Avatar
Quoted: 69 Post(s)
A 255\70\22.5 measure out to be a 36.4 inch tall tire and with a leveling kit, will fit no problem
Sent from AutoGuide.com App
Nick
E99/CC/Lariat/Factory Wide Body Kit
"The Mistress"
Power Hungry Performance HYDRA Chip
Custom Tuned by Bill@PHP, Tony Wildman@Total Diesel Performance and Lars@Gearhead
D66 w/Dieselsite WW2, Full Force 250/100s, Adrenalin HPOP, Built Trans, Walbro Fuel Pump, S&B Intake, 6" Stacks, Leveling Kit, Eagle Alloy Wheels, 315/75/16 Grabber AT2s & Much More
HVAC SuperTech is offline
post #10 of 97 Old 06-08-2014, 09:28 PM
StrokinAlaska's Avatar
I'mso lost on what to do on my dually rim wise. I want to go bigger even if its just newer factory ones. My 16s are just ugly but I'd use them in the winter still. I don't want to get too crazy in price but I'd like to look different then everyone else around here. Not too many duallys on rims up here! I also don't tow, anything but my *** around town.
05-07 Front
GlowShift Gauges
AFE C.A.I
4" d.p
TS-Performance 6 Position Chip
Wicked Wheel 2
Coolingmist Stage 1
14lbs Nitrous Oxide
(2) 52" VisionX Xmitter Led bars
VisionX Cannon 4.7"
VisionX Cannon 6.7"
(2) 42" RaceSport Led bar
(4) VisionX Solo Soltice
(4) RaceSport Duallys
Hids
Alpine INE-S920HD
20 Speaker Rockford Fosgate Stereo System
3 Bulk Packs of Ballistic
Smoked Cab Lights, Fender Lights, SwitchBack Leds
Tint
2.8" Front leveling kit
StrokinAlaska is offline
