Go Back   Ford Powerstroke Diesel Forum > General Topics > General Diesel Discussion > Dually Discussion
Old 11-12-2008, 03:40 AM
willholl79 willholl79 is offline
Dually tire size.
Will 35x12.50 fit on '96 stock alumin. dually wheels? I know i'd have to put spacers in the rear.
Old 11-14-2008, 09:50 PM
ricksstang ricksstang is offline
A 35 X 12.5 will require a wheel that is at least 8.25 in wide and would work best on a 10 in wide wheel.
Rick
Old 11-16-2008, 08:14 PM
diesel hubbz diesel hubbz is offline
Send a message via AIM to diesel hubbz
how wide is a stock dually rim?? would a stock dully rim work with 315/75r16? will it need spacers in the rear?
Old 11-17-2008, 08:16 AM
MrJohnWayne MrJohnWayne is offline
Thats Mr. Oil Leak.....
stock dually rims are 6.5 inch wide IIRC
Old 11-17-2008, 05:13 PM
can you fit 315/75r16s on that rim? or do i need to run wider
Old 11-17-2008, 05:14 PM
mudrunninpig mudrunninpig is offline
D80 Axle Snapper
I am runnin 37x12.5x17 on stock 06 rims.
Old 11-17-2008, 05:40 PM
dually rims? how wide are they?
Old 11-17-2008, 06:20 PM
D80 Axle Snapper
stock rims should be 6.5 wide
Old 11-17-2008, 06:49 PM
damn do you have any full size pics so i can see? did you run any spacers? what sizes?
Old 11-17-2008, 11:39 PM
wheel sizes
Rick
I got these recommended wehhl sizes off of tirerack.com. Look up the size and brand and type tire and go to specs, and you will find the recommended wheel sizes.
I am not saying that you cannot get it on a narrower wheel, it just is not recommended by the manufacturer.
Tire Specs for BFGoodrich All-Terrain T/A KO
Rick
