Go Back   Ford Powerstroke Diesel Forum > General Topics > General Diesel Discussion > Dually Discussion
  #11 (permalink)
Old 11-18-2008, 03:10 AM
diesel hubbz diesel hubbz is offline
Send a message via AIM to diesel hubbz
have you found an 8.25 inch wide dually rim? i havent... any help? if hes running 37 12.50s on a 6.5 rim then i dont understand why a 35 would have problems?
  #12 (permalink)
Old 11-18-2008, 04:55 AM
willholl79 willholl79 is offline
When I'm done with the 4wd conversion I'm gonna try 315/75r16s.
  #13 (permalink)
Old 11-18-2008, 06:17 AM
mudrunninpig mudrunninpig is offline
D80 Axle Snapper
Here are some pics 37x12.5x17 bfg km2 on stock rims. Custom hubcentric 2" wheel spacers from No Limit Off road. I have 35,000 miles on this set up with no issues so far. I am only runnin wheel spacers on the rear.
  #14 (permalink)
Old 11-19-2008, 01:45 PM
jaaron jaaron is offline
Do your front tires rub at all when you turn?
  #15 (permalink)
Old 11-19-2008, 02:39 PM
460+ 460+ is offline
Im running 315-75-16's on mine. Ive seen 38-13-16's on a truck with spacers. As far as rubbing with 315-75-16's they wont. Hope this helps.
  #16 (permalink)
Old 11-19-2008, 07:05 PM
D80 Axle Snapper
Mine do not rub
  #17 (permalink)
Old 12-11-2008, 11:50 AM
Well i found some tires that i ant to get and they are 13" wide. I am congident that the will be ok with stock rims but what will happen if i throw them on some taller rims? Willi be better off with 16in or go bigger like 18's or 20's?
  #18 (permalink)
Old 12-11-2008, 11:58 AM
flowmasters40 flowmasters40 is offline
Send a message via AIM to flowmasters40
YES a 35 will fit on a factory obs dually wheel
  #19 (permalink)
Old 12-11-2008, 12:05 PM
TYREBOYS_DEMAXIN TYREBOYS_DEMAXIN is offline
you can fit a 35-12.50 tire on a 6.5 wide dually wheel is it recommended NO but possible just some things to keep in mind if you do..you will spacers which has been mentioned,keep the PSI regulated since to much air will wear the center of the tires rather quickly and last but not least keep enough air in them that its safe.
  #20 (permalink)
Old 12-11-2008, 12:34 PM
I already have 35's with a 2in spacer i was just wondering aboout running 37's and if it would be better to run a taller or a shorter rim
