10 or 13 Speed? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 03-03-2014, 03:03 PM Thread Starter
WVRidgeRunner's Avatar
10 or 13 Speed?
I know the 7.3 came in several medium trucks and was wondering if anyone here had seen or put a 10 or 13 speed in their dually? On board air and a divorced transfer case would be a necessity but it would really wake these trucks up. I have 4.11 gears so it would be awesome to always be at the ideal rpm range and have a huge drop in rpm in high gear, especially unloaded.
1999.5 707 Conversions Super Duty 7.3 Crew Cab LB Dually 4x4 Edge Evolution, Oil HPx, Fuel FRx, tons of filters, hutched n harpooned, B&W turnover ball and 5th wheel, lotsa goodies.
WVRidgeRunner is offline
post #2 of 6 Old 03-06-2014, 08:16 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
There is a guy planning it in the idi section, but seems like a lot of shifting for in town use, but would increase life and passing power
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 6 Old 03-07-2014, 01:14 AM Thread Starter
Most of the time unless your riding heavy you'd take off in at least 4th so it's not as bad as it sounds. From what I've found, there's a straight 10 speed available in certain IH 7.3 busses that is synchronized so no air required and no double clutching (which most of us drivers don't do anyway). As long as our block accepts the SAE bellhousing, should be close to a bolt in, with minor tranny hump and mount mods. Just have to come up with a divorced transfer case. I'm still looking into it but it's one of those long term down the road projects for now. I like to plan way ahead so if I accidentally run into the parts I need I have a plan in place. I swear I'd put an 18 speed into everything I owned if I could figure it out, although that would make our Honda pilot do 300 mph lol. The 6 speed on my victory bike is so much smoother than some of my older bikes, I can only imagine what it would be like to go from a 4 speed auto to a proper truck tranny in this dually.
post #4 of 6 Old 03-07-2014, 04:27 AM
Quoted: 3 Post(s)
did you look into maybe doing a gear venders unit?
2000 DRW CC 7.3
Exterior: 08 Exterior Clone, 22.5's
Engine Mods: GTP38R WW2, 5 inch exhaust,T500, 6637, TW tunes,DI Up pipes, 6.7 fuel pump fuel system.
Trans Mods: 6.0 trans cooler, JW Valve body,Billet triple disc converter.
Sound Mods: 7" flip out tv, 3-way speakers all around, 12" sub, 500 watt amp.
Misc:dieselsite coolant filter, max ac assist, BRV, IHD,gauges, CCV
Next up power rear window
campbellflage is offline
post #5 of 6 Old 03-07-2014, 06:49 AM
dannanw's Avatar
Quoted: 54 Post(s)
Garage
I've looked, but I cant justify the 4-6k... unless I was doing hot shot type work, but then I'd get a FL60 or similar.
What this nation needs is cleaner thoughts and dirtier fingernails...
dannanw is offline
post #6 of 6 Old 03-08-2014, 09:05 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Just run a divorced np-205
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
