Go Back   Ford Powerstroke Diesel Forum > General Topics > General Diesel Discussion > Dually Discussion
Old 11-07-2008, 07:49 PM
podirtfarmer podirtfarmer is offline
Looking for info
I am looking to convert my 1999 F250 2wd shortbed supercab to a dually I have the chance to pick up a 1999 f350 4wd complete for a very good price I would be able to pull bolt on from front hubs to complete that. My question is will the rearend bolt up to my springs or are there any differences I need to look at This truck is also going to be getting a 3"drop in the front and 5"in the rear. Any info would be great thanks
Old 11-07-2008, 07:51 PM
HVAC SuperTech HVAC SuperTech is offline
Scott loves the Squirell
you need the complete rear end, and it should just bolt right up. also, you will need the front hub assembly, or the spacers that they use. Either one. you have a bed?
Old 11-07-2008, 07:53 PM
no bed yet I have been looking for fenders and will have to modify because of the location of fuel fill. I will have the whole truck I just have had several people tell me that there are several widths on the rearend
Old 11-07-2008, 07:54 PM
if you have a 350 rear end, it should bolt right up. A 450 or 550 rear might be wider. I am unsure.
Old 11-07-2008, 08:11 PM
thanks I think I will just buy the other truck and then part out what I dont need and should be able to do conversion any other info would be great
Old 11-13-2008, 02:21 PM
Well the rear end would not fit it was not wide enough spring packs were narrow compared to my truck will have to start looking again. I did find out though that there is a difference in fram widths on these trucks
Old 11-13-2008, 03:45 PM
There is a difference between the 450/550 and the 250/350s?? I thought that might be the case. I know that the 350s and 250s have the same frame.
