need advice! lowering 4x4 dually ? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 02-13-2014, 03:11 PM Thread Starter
We've got a 2008 f450 dually show truck currently leveled on 24" semi wheels. Want to change it up a little bit and see what available for lowering it bags or not.
Ive searched and searched and cant find any solid info or kits... i would really just like to flush out the wheels more then anything so nothing more then 2-3" is really necessary at all.
i would appreciate all help or advice
2010 sti
08 f250
Airaid intake, black max, 5" turbo back (dpf delete)off road only ofcourse
Tint, brushgaurd piaas, hid upgrade, piaas in the back, piaa fogs, lots more and more to add. Any suggestions?
clutchdabomb22 is offline
post #2 of 6 Old 02-18-2014, 03:57 PM Thread Starter
need help guys please
2010 sti
08 f250
post #3 of 6 Old 02-19-2014, 05:55 AM
dannanw's Avatar
Quoted: 66 Post(s)
Garage
check out DJM, Belltech, or Groundforce
What this nation needs is cleaner thoughts and dirtier fingernails...
dannanw is offline
post #4 of 6 Old 02-19-2014, 05:57 AM
1ofakind79's Avatar
Quoted: 2 Post(s)
If you only want to go down 3" from your current just take off the leveling kit and pull out the rear block and that should get you 3" lover than current.
2000 F350 CC Dually 4x4 Lariat 7.3 6spd, Leveled, 05 front end & mirrors, 4" turbo back, 38R, WW2, regulated return, Airdog 150, intake, Swamps IDM, tuned by PHP, Gear Vendors, 19.5s
Coming soon: 250/200s, studs, stealth hpop, as soon as I get springs and pushrods.
1ofakind79 is offline
post #5 of 6 Old 05-22-2014, 05:54 AM
I know its a little backyard but cut coils in the front....rear I would start with removing the block see what that looks like than maybe removing leafs....
lifted 6 is offline
post #6 of 6 Old 05-22-2014, 07:48 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Go to gasser leafs they should squash more under a diesel, remove rear blocks and just 4 link the rear
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
