GEAR GURUS: Gear swap questions..... - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 12 Old 02-09-2014, 12:38 PM Thread Starter
Doesn't Even Care
HVAC SuperTech's Avatar
Quoted: 69 Post(s)
My truck came with 3:73s from the factory. Since putting on my 33s and now 35s, I thought about doing a gear swap to 4:10s and getting a limited slip instead of my open rear diff. I would rebuild the Trac loc or LS before putting it in.
My question is can I just get a used gear set and carrier out of a 99-03 Dana 80 and put change mine out with no issues? Or would it be more complicated than that?
I want to do this on the cheap, or im not gonna do it at all. If I was to look at buying a gear set from yukon, Richmond ect... I would have to find a carrier also, as they are different when you go from a 373 gear to the 410s.....am I correct in this thinking? I know the Detroit tru tracs are different for each set
Sent from AutoGuide.com App
Nick
E99/CC/Lariat/Factory Wide Body Kit
"The Mistress"
Power Hungry Performance HYDRA Chip
Custom Tuned by Bill@PHP, Tony Wildman@Total Diesel Performance and Lars@Gearhead
D66 w/Dieselsite WW2, Full Force 250/100s, Adrenalin HPOP, Built Trans, Walbro Fuel Pump, S&B Intake, 6" Stacks, Leveling Kit, Eagle Alloy Wheels, 315/75/16 Grabber AT2s & Much More
HVAC SuperTech is offline
post #2 of 12 Old 02-09-2014, 01:37 PM
It is more complicated than that. I personally would not use used gears. When you set them back up, even if you do it correctly they will be loud as ****. There is nothing "cheap" about what you want to do. 3.73 to 4.10 isnt enough of a change to me to spend that kind of money. I'm just talking parts too, I can do the work myself.
tech701 is offline
post #3 of 12 Old 02-09-2014, 03:46 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Honestly why not just swap the axles out? Willing to bet someone would want a "slightly" better hwy gear and swapping the entire axle is less complicated then swapping gear sets
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #4 of 12 Old 02-09-2014, 03:52 PM Thread Starter
Doesn't Even Care
Quoted: 69 Post(s)
Thanks for the responses guys. I just wanted to get some of that get up and go back on my truck since I went to larger tires.
Axle swap isn't gonna be easy either. Id have a hard time trying to find someone that would give up towing capacity for just a bit better mileage. But that is a good idea....
Nick
"The Mistress"
post #5 of 12 Old 02-09-2014, 04:11 PM
Quoted: 27 Post(s)
If all the teeth on the ring and pinion are in good shape with good wear pattern I see no problem with it. Also if you're not there when they come out of the axle make sure the ring and pinion match each other as they are machined as a set when made. Maybe a local junkyard will let you pull the diff cover to inspect and if it looks good than buy the whole axle? Just a thought.
strokin-7.3 is offline
post #6 of 12 Old 02-09-2014, 04:26 PM
ZMANN's Avatar
Quoted: 1563 Post(s)
even if u do the used gears the rest of the install kit would be new unless you use the old bearings not sure what used gears would cost but i don't see a huge savings ?
and if this is your first gearset install I wouldn't even let you do mine for Free I would gladly pay a good shop to do this and they wont likely warranty used gears not the installation of them
no offense but this can be more than a book sense procedure to get it set properly
the risk of a bad install can cost you the whole axle housing in the event of a failure
We Miss you Ronnie
ZMANN is online now
post #7 of 12 Old 02-09-2014, 04:37 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
You wouldn't believe how many people have a Dually never hooked to anything
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #8 of 12 Old 02-09-2014, 04:43 PM
Quoted: 27 Post(s)
x2 I personally won't do gears on anything I daily drive but did do gears in my dana 44 (eventually going in my ranger when funds are available). It did take me a while as I would get frustrated and just walk off. Started taking notes as to what shims caused what and eventually got it done.
ZMANN likes this.
post #9 of 12 Old 02-11-2014, 09:29 AM
I would love to swap my 4.10's for 3.73's!
I am not here! I am Gone! I highly doubt I will ever be back!!!
48kenworth is offline
post #10 of 12 Old 02-12-2014, 03:28 PM Thread Starter
Doesn't Even Care
Quoted: 69 Post(s)
Little far away...lol..But that would be a sweet option!
Nick
"The Mistress"
