Steel Dually Spacers - Ford Powerstroke Diesel Forum
 2Likes
post #1 of 50 Old 01-31-2014, 10:31 AM Thread Starter
Looking for steel 2" or 3" rear wheel spacers. Who makes the most proven and strongest ones. I've seen it mentioned in here before but can't seem to find it when I need it.
Thanks
tech701 is offline
post #2 of 50 Old 01-31-2014, 10:38 AM
kinnisoj's Avatar
Quoted: 2 Post(s)
Check out wheeladapter.com. These seem to be what the big boys are runnin.
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #3 of 50 Old 01-31-2014, 02:20 PM Thread Starter
Wheeladapter.com seems a bit pricey. Didn't I see a set for a couple hundred bucks on here a while back?
tech701 is offline
post #4 of 50 Old 01-31-2014, 02:25 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
I found a set on ebay (aluminum) that was like $119 if I remember right.
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #5 of 50 Old 01-31-2014, 02:26 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
Some pretty good info if you look in the lifted dually thread.
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #6 of 50 Old 02-01-2014, 06:05 AM
99bft's Avatar
Im running arrowcraft spacers on mine. They use factory style lug nuts and there hubcentric which you have to use on these trucks. You can check out there website but you'll have to call them to order them. They are extremely nice and helpful. I believe there made out of timken bearing steel. Mine where just a little over 200 shipped but that was a couple years ago. Ive put over 30k on them with some heavy loads without any trouble.
99.5 F350 CREW CAB DUALLY 4X4, 4:10 (LS),ZF6 SWAPPED, RANCHO 2.5"LIFT, 305/70/16 NITTOS, RHINO LINED, B&W TURN OVER, TEKONSHA PRODIGY P3, MBRP 4" TURBO BACK, K&N CAI, PHP Hydra, Riffraff AIH DELETE, BILLET COMPRESSOR WHEEL, HPX,& "OCR", NON EBPV PEDESTAL, HIGH FLOW EXHAUST HOUSING, FOIL DELETE, ZOODAD, ISSPRO EV2 GAUGES, 6.0 TRANNY COOLER, EXTRA QUART POLISHED DIFF COVER, WARN HUBS, ARROWCRAFT SPACERS, ALPINE TOUCH SCREEN
OTHER TOYS:
65 N600 390
67 N1000 220 CUMMINS
99bft is offline
post #7 of 50 Old 02-16-2014, 10:58 AM
Doesn't Even Care
HVAC SuperTech's Avatar
Quoted: 69 Post(s)
You DON'T WANT aluminum spacers...They will snap studs. You're gonna want wheeladapter.com spacers or arrowcraft
Sent from AutoGuide.com App
Nick
E99/CC/Lariat/Factory Wide Body Kit
"The Mistress"
Power Hungry Performance HYDRA Chip
Custom Tuned by Bill@PHP, Tony Wildman@Total Diesel Performance and Lars@Gearhead
D66 w/Dieselsite WW2, Full Force 250/100s, Adrenalin HPOP, Built Trans, Walbro Fuel Pump, S&B Intake, 6" Stacks, Leveling Kit, Eagle Alloy Wheels, 315/75/16 Grabber AT2s & Much More
HVAC SuperTech is offline
post #8 of 50 Old 02-16-2014, 01:53 PM
Quoted: 728 Post(s)
I too was on the anti-aluminum band wagon. But personally I have never read of heard of any aluminium spacer failing. Here's a company that has lifetime warranty on theirs. Type of aluminium makes a big difference though.
http://www.motorsport-tech.com/4DCGI/switchtruckmodel
Corey@CNCFAB is offline
post #9 of 50 Old 02-16-2014, 02:07 PM
schlutzer's Avatar
Quoted: 18 Post(s)
Wheel Adapters, Wheel Spacers, Hub Centric Rings | Motorsport Tech
Those BORA spacers are pretty awesome, I have some that just need to go on, I've ran 3 sets of them now ( different trucks). Good aluminum bolt on spacers should be fine. They have to be stronger than the cast aluminum stock wheels.
Please check out my 7.3 Enthusiast Facebook group! All are welcome!
schlutzer is offline
post #10 of 50 Old 02-16-2014, 03:07 PM
Don't you worry about it
strokinpower's Avatar
Quoted: 270 Post(s)
My friend put aluminum spacers on his duramax and tore off down the road and one of his back wheels passed him. Snapped off the lugs.
2014 Platipus
AP Intake
Spartan EZLYNK
4" Dual Exhaust
4" BDS with Fox shocks and PMF stage 2 traction blocks
strokinpower is offline
