to cover or not to cover - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By RollinEarly99
post #1 of 6 Old 12-24-2013, 01:17 PM Thread Starter
oldtrojan66's Avatar
I think I know the answer, and I did a search of several key words with no success. What is the conventional wisdom concerning the use of a pad or some sort in front of the radiator in cold weather? I have seen some big rigs with this set up, but not nearly as in past times. Thanks for your help in advance.
oldtrojan66 is offline
post #2 of 6 Old 12-27-2013, 08:17 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Search cold front, or cold fronts, but honestly a piece of cardboard behind the grill works too, and several have just made one
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 6 Old 12-30-2013, 07:28 AM
By keeping the extreme cold temps away from the rad the engine can build and maintain the heat its creating affectively. In return we can generate heat faster and keep the engine at operating temperature making it more efficient in winter temps.
Worth every penny, cardboard or other if you drive in the cold!
cuda66 is offline
post #4 of 6 Old 12-30-2013, 02:39 PM Thread Starter
Thanks for the help!
post #5 of 6 Old 12-30-2013, 02:47 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
Spray paint the card board black... Then it isn't noticeable to others while driving!
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #6 of 6 Old 01-01-2014, 04:48 PM
picked mine up from amazon its a fia and it was $53 shipped to my house made a real big difference. our temps have been -20 to -35 here the last few days with windchills
2011 F350 DRW lariat Spartan tuned, 4" straight piped exhaust,afe stage 2 CAI,SDP egr delete and more coming
Sold 12 ram 2500 and dont miss it!!!
E99 F350 7.3L parts on the way
skinnysfd is offline
