Go Back   Ford Powerstroke Diesel Forum > General Topics > General Diesel Discussion > Dually Discussion
Old 09-04-2008, 06:11 AM
baja38ss baja38ss is offline
Question on tire size???
Hey guys need some help. I'm running a 01 crew dually with the stock
235x85x16. I have a 2" leveling kit with the shackels on the front leaf springs.
Can I put bigger tires just on the front. The 2" kit is a little shy to level it out.
What size can I put on??Need another 1" or so. Story of my life LOL
Thanks for any help
Old 09-04-2008, 07:00 AM
krazeehorse krazeehorse is offline
You really shouldn't go any bigger if it's 4 wheel drive. If it's 2WD then no problem as long as you don't get too wide on the stock rim.
Old 09-04-2008, 11:35 AM
goodriddance goodriddance is offline
I have 265/70/17 on my stock truck, and could probably go bigger yet
Old 09-08-2008, 06:23 PM
tires??
Thanks for the help. It is a 4x4 I wasn't sure if I could change just the fronts to a bigger size or not. Tires are not matched so the fronts are Goodyears which are more like a summer tread, which really sucked in winter. So I was thinking changing them out and wanted to go bigger at the same time if I could.
Old 09-16-2008, 05:32 AM
73LSTROKER 73LSTROKER is offline
ABS requires all tires to be the same diameter, 4X4 or 4X2.
STROKER
Old 09-16-2008, 05:34 AM
jhaddox jhaddox is offline
Send a message via AIM to jhaddox
abs and not positive but isnt it if the tires arent spinning at the same rate the 4x4 wont engage
Old 10-08-2008, 10:32 PM
lilredpowerstroke lilredpowerstroke is offline
Powerstroke Pimpin'!!!!!!
Im running 305/70 Swamper SSR's and 34x10.5 TLB's in the back. They arent exactly the right size but as long as im in the dirt it dont matter, on the pavement it binds up only when I turn.
