Dana 80 dwr info - Ford Powerstroke Diesel Forum
post #1 of 8 Old 11-16-2013, 07:55 AM Thread Starter
Motor Head.
robertc68's Avatar
Quoted: 39 Post(s)
Dana 80 dwr info
Does anyone know where I can get info on the differences between the dana 80, specifically between 99-04 and 05plus.I know the lug bolt pattern is different 8x170 vs 8x200,but I am more so looking for axle interchange ,and hubs and brakes from the 05 and up working on the 04. Thanks
04 350 DRW CC LB,4:10,245/75/17,tires 4X4..Coolant filter. CTS.Stage II AFE.EGR Delete,Zoodad ,regulated return, ,Arp,OemHG,AD150,WPE ported int,58FICM,190/30 Injec,05 coil conversion.WPE/KC 1.5 turbo,2011 rear leafs,13 tailgate,flight fab trac bars.2014 Power/folding/Extend mirrors.
robertc68 is online now
post #2 of 8 Old 11-16-2013, 10:42 AM
portcity_gt's Avatar
Quoted: 1456 Post(s)
I know the 05 is wider...so I would think the axles wouldnt swap.
03 cclb dually,6.0,arp studs,bpd oil cooler,bpd 6 phase ficm,bpd water pump,bpd all aluminum cac,all aluminum radiator,amsoil bypass oil filter,ipr high flow coolant filter,egr delete,livewire ts tuned by Vivian & tony,php ficm tuner,dc power 300-spx,Detroit trutrac,6" dual side pipes,07 front end,custom front bumper,shaved badges,led button roof lights,08+ mirrors,12 tailgate,13 rear bumper,13 tail lights,dropped I beams,custom rear 4 link w/bags,k5la train horn,24" alcoa's.
portcity_gt is offline
post #3 of 8 Old 11-16-2013, 11:05 AM Thread Starter
Motor Head.
robertc68's Avatar
Quoted: 39 Post(s)
Are you meaning hub to hub measurement or tire outside dimension?
post #4 of 8 Old 11-16-2013, 11:14 AM
The rear end it self. Hub to hub.
post #5 of 8 Old 11-16-2013, 11:18 AM Thread Starter
Motor Head.
robertc68's Avatar
Quoted: 39 Post(s)
Ok thanks,do you know if the hubs interchange , I do know the inner bearing is the same 99 to 04, then mid 06 and up.
post #6 of 8 Old 11-16-2013, 11:31 AM
No, I dont know on that one.
post #7 of 8 Old 11-16-2013, 11:48 AM
I tried to Google a pic with the same angle. These trucks have the same wheels.
You can see my 03 sticks out less than the 05
03
05
post #8 of 8 Old 11-16-2013, 01:08 PM Thread Starter
Motor Head.
robertc68's Avatar
Quoted: 39 Post(s)
03
05
Ok I see what you mean.Guess there is no way around it other then changing the whole housing assembly.i have adapters that get me from 8x170 to 8x200 but was looking down the road.
