Go Back   Ford Powerstroke Diesel Forum > General Topics > General Diesel Discussion > Dually Discussion
Old 08-03-2008, 12:29 PM
tabraha tabraha is offline
Clearance Light bulb replacement
One of my "chicken lights" on the fender has burnt out, before I just go at it with a screwdriver is there a special way or recommended way to get this booger out for a bulb change?
Old 08-03-2008, 12:58 PM
Southpaw Southpaw is offline
1/20/2013
I don't own a dually, but I would assume if theres no visible screws on the outside, that it would come out from the inside of the fender. Sinilar to a lisence plate bulb or even a headlight bulb. Look up in there and see if you can turn the back of the bulb housing a 1/4 turn or so anf pull it out.....
Old 08-03-2008, 02:53 PM
460+ 460+ is offline
You have to pull the inner liner loose, then you can access the light. Also there is a clip that holds the light to the fender.
Old 08-03-2008, 07:58 PM
Thanks guys; that won't be a big deal at all then. Figured that might be the case but I decided a quick post before digging in might be a good idea. I've been contemplating the RECON LED replacements, might be good timing!
