Question on converting from DRW to SRW - Ford Powerstroke Diesel Forum
post #1 of 13 Old 10-25-2013, 11:58 AM Thread Starter
06superduty3997's Avatar
I know this question has been asked alot, and most would say just go out and buy and SRW super duty, but I dont want to do that option. So if I cant find a buyer for my truck, I have plans on converting it to a SRW. I can get my hands on an SRW 8ft bed super duty bed, but other than that what else would be needed for the conversion. Any help would be apperciated.
2008 F-350 FX4 CCLB 6.4 Powerstroke
SCT Livewire With RCD Tunes. Magnaflow 5" Straight Pipe Exhaust with an 6 inch tip
Airaid drop in filter with a modded stock box. Halo/LED headlights, LED Mirror, Dually Fender Lights.
2.5 leveling kit Soon to Come,
Road Armor Front Bumper with Pre Runner Bar.
AF 19.5 wheels black
LED D2s and light bar
06superduty3997 is offline
post #2 of 13 Old 10-25-2013, 10:31 PM
I am going to ask why? This is ment to offer you more help. If I know your goals it may change what you will need to do. I did a srw to a drw swapp witch is a little harder if you do it right.
godfryness is offline
post #3 of 13 Old 10-25-2013, 10:34 PM
I believe there are supersingle kits out there and the last one I saw on a F450 looked great.
2013 F 350 King Ranch all stock
Big Tex 14 GX Dump Goose neck Trailer 14k GVWR
25' Flat bed Dovetail Goose neck Trailer 16k GVWR
M 101-A2
Traxx is offline
post #4 of 13 Old 10-25-2013, 10:36 PM
Can you post a pic to have a better idea?
post #5 of 13 Old 10-25-2013, 10:38 PM
So just a supper single, no better mpg, faster highway speeds, or only 4 tires to worry about? You just want the look of a srw truck
post #6 of 13 Old 10-26-2013, 05:46 AM Thread Starter
Traxx would you happen to have a link
post #7 of 13 Old 10-27-2013, 06:21 PM
Diamond Off Road Customs - Home
I couldn't find a pic of his truck here. It is the owners personal tow rig.
M 101-A2
Traxx is offline
post #8 of 13 Old 10-28-2013, 11:16 AM
Ok I am going to give you my .02 cents to help. I converted a 2002 f350 SB SRW to a DRW. Now its going to be a little different because your truck is an 08?
Its really simple for you because you don't need to swap axles, you already have a dana 80 where I had a sterling 10.5 witch is narrower then the D80. I could have put on spacers but that is not the ideal way to go so I did an axle swap.
You should just need to pull off your rear dually fenders and have your bed holes covered and painted. Or if you can find a SRW bed of the same color for cheeper, then sale your bed and you should come out even.
The big question is this. Dont quote me but from 99-04 SD used 8/170 bolt pattern on the rims for both SRW and DRW. So to just pull off the fenders or replace the bed from a DRW and find rims is no problem. The rimes all are the same. In 2005 and later, the SRW SD stayed 8/170. The DRW changed to 8/200. Now since yours is 8/200 you will need to find out if any one makes non DRW rims on a 8/200. If so your don't need to swap axles.
You really don't want to swap axles because yours is stronger and its only around 3 in wider then the SRW axle. If I recall and maybe someone with chim in if I am wrong but at least for the 99-04 the sterling is a 7,500 LB axle where as the D80 is a 12,000 LB axle. So you can see why you would like to keep the D80. I ran SRW on my D80 with out a dually bed for year and it look very normal. Only a few guy could tell it was wider, and thats because the disk was exposed and not covered by the rim.
Now if no one makes a SRW rim in 8/200 mabye you can converit some how? I am not sure on that. Or at that point just swap axles from a like year SRW SD. Remeber if you swap axles and yours is 4x4 you have to match your gears. I had to change my front d60 from 3:73 to 4:10 so they would match my new D80. It was fine with me because I wanted lower gears.
Hope this helps. if you swap axles every thing is a direct bolt on process. Remember please double check what info I gave you. I am 99% sure every thing I said is correct but I did it on an 02 not an 08 SD.
good luck and post pic
post #9 of 13 Old 10-28-2013, 12:13 PM
portcity_gt's Avatar
Quoted: 1279 Post(s)
The dually beds are cut out at the fender wells, it will either need a new bed or new bed sides. You will also have to change out the front hubs.
03 cclb dually,6.0,arp studs,bpd oil cooler,bpd 6 phase ficm,bpd water pump,bpd all aluminum cac,all aluminum radiator,amsoil bypass oil filter,ipr high flow coolant filter,egr delete,livewire ts tuned by Vivian & tony,php ficm tuner,dc power 300-spx,Detroit trutrac,6" dual side pipes,07 front end,custom front bumper,shaved badges,led button roof lights,08+ mirrors,12 tailgate,13 rear bumper,13 tail lights,dropped I beams,custom rear 4 link w/bags,k5la train horn,24" alcoa's.
portcity_gt is online now
post #10 of 13 Old 10-28-2013, 06:57 PM
good point. i forgot about the front hub spacers.
