Help on tires and wheels. - Ford Powerstroke Diesel Forum
post #1 of 13 Old 10-24-2013, 03:00 PM Thread Starter
Ok so I have ran in to a problem, I am looking to put on some KMC XD rock star dually wheels in 17in on my 2002 F350 dually. This is where the problem starts. KMC makes the wheel I listed in a 17x6.5 8x170 bolt. Thats is what my truck is, so no problem right? NO, I cant find any where a steel inner wheel that is 17 in 8x170 dually wheel.
What I don't understand is if KMC and others make a dually 17in wheel 8x170 then to buy and use it you have have to have a 17 in steel rim to go with it. So where can you get them? Or how is anyone using these rimes sold by KMC and others? Every tire place I have called has no idea. I sent an email to KMC with no response. Please help, I like these rimes and I already have 4 new 17 in tires to put on them so thats a huge part of why I want 17 in rimes.
godfryness is offline
post #2 of 13 Old 10-29-2013, 12:07 PM
CNYWhiteDually's Avatar
my stock steels are 17's
CNYWhiteDually is offline
post #3 of 13 Old 11-03-2013, 05:10 PM
Stock inner steals on my '05 are 17"
05 CC DRW
4" t/b Magnaflow
Edge Evolution
nhra6002 is offline
post #4 of 13 Old 11-11-2013, 07:27 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
05+ is 8x200, he needs 99-04 wheels guys, they were 16" in those years
Places like discount tire should sell that 17" inside wheel, have you ordered the wheels yet?
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #5 of 13 Old 11-11-2013, 07:39 PM Thread Starter
No one makes a 17 in dually wheel for 8x170. My tire shop said that you can get rock stars in 17in by 8x170. As I looked closer it's not true. Just 8x200. Now I have another question. How hard is it to convert the rear d80 hub to 8x200? Expensive? Possible?
post #6 of 13 Old 11-11-2013, 07:49 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Just swap the axle entirely, and the extensions on the front hub assuming yours is 4x4, if 2wd then swap the rotor out
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #7 of 13 Old 11-11-2013, 08:39 PM Thread Starter
Thanks, that answered my question. I will just have to stay with the 16's. Now I have a what if question.
If I ran 16's in the rear and 17's up front with the same high tire, would that be a problem?
post #8 of 13 Old 11-12-2013, 11:59 AM
As long as the tire circumfrence/diameters are the same there shouldn't be a problem. If it's 4wd.
05 CC DRW
4" t/b Magnaflow
Edge Evolution
nhra6002 is offline
post #9 of 13 Old 01-04-2014, 09:45 PM
cypher0807's Avatar
I'm running 18" up front, 17" rockstar outer and factory 17" inner steel.
Proudly STILL serving!!!
cypher0807 is offline
post #10 of 13 Old 01-05-2014, 05:01 AM
Did your truck start off as a dually or did you convert it? Why did you not just run 17s up front too?
2006 Ford Powerstroke Super Cab 4x4 auto 120K bulletproofed
ramz trk is offline
