white smoke - Ford Powerstroke Diesel Forum
post #1 of 5 Old 10-13-2013, 02:13 PM Thread Starter
white smoke
My 2010 f 250 diesle is blowing white smoke have had new cooler assembly unit install still blowing white smoke any suggestions
rjeep is offline
post #2 of 5 Old 10-14-2013, 07:44 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Checked oil and coolant for mixing?
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 5 Old 10-16-2013, 08:13 AM
geoff426's Avatar
First off, I am not a mechanic, I just have my experiences. When I had an injector go bad my truck started blowing some white smoke. As I continued to drive it, it got darker and darker. It was blowing a lot, enough to cloud a street. Hope yours is an easy inexpensive fix.
2003 F350 DRW
BPD oil cooler Air/Oil
BPD EGR cooler
Holders Diesel 175/30 injectors
KC Stage 2 Turbo
UCF O-ringed heads
ARP studs
4" exhaust
BPD mechanical fan clutch adapter/7.3 clutch
blue spring
geoff426 is offline
post #4 of 5 Old 10-24-2013, 08:40 PM
it could be the high pressure turbo shaft broken sending oil into the exhaust,or an injector,could also be a bad particulate filter
romy7913 is offline
post #5 of 5 Old 10-29-2013, 06:53 PM
6X6
6X6's Avatar
I'm really not trying to be funny..........but your up in Canada and it's cold up there. Are you sure it's not just cold exhaust? diesels blow white exhaust when it's cold out.
2012 F-350 DRW
CC 6.7 Gear 373
6x6 172wb
Lariat 13300 GVW
6X6 is offline
