Go Back   Ford Powerstroke Diesel Forum > General Topics > General Diesel Discussion > Dually Discussion
Old 07-09-2008, 06:27 AM
RollinEarly99 RollinEarly99 is offline
7.3 with a 5r110
I was wondering if anybody knew if a 4r100 can be replaced with the 5r110?
Old 07-09-2008, 03:45 PM
Is there a place that sells the adaptor plate?
Old 07-09-2008, 03:51 PM
Marty Marty is offline
International Threat
Yes but it's considered a waste when you can get your 4R100 built to be stronger then the 5R110 for the same price or cheaper.
Old 07-09-2008, 03:53 PM
Dave Dave is offline
Vikings cheerleaders YUM!
It would take alot of work to do it. You would need an adapter plate, TCM and a way to make the PCM and TCM communicate. or a standalone trans controller. By the time you do all that it would be alot more cost effective to have BTS or John Wood build your 4r100
bigcountrysg bigcountrysg is offline
duct tape & zip ties
Old 07-09-2008, 03:57 PM
I've thought of that, but wouldn't your fuel mileage go up considering you got 5 speeds?
Old 07-09-2008, 03:59 PM
Still with the expense I could do other things to get better fuel mileage. Like add an external overdrive unit.
Old 07-09-2008, 06:08 PM
No, the final drive is still the same ratio. .71.
Old 07-29-2008, 07:22 AM
nc1500 nc1500 is offline
The Road Warrior
For about the same money you could rebuild the 4R yourself and add a mechanical overdrive. This would give you 8 ratios. I'm thinking about this myself.
Old 07-29-2008, 07:45 AM
bigwhite7.3stroker bigwhite7.3stroker is offline
Florida Stroker
Keep your tranny and get it built
