MY SRW VS MY DRW - Ford Powerstroke Diesel Forum
post #1 of 3 Old 08-19-2013, 10:00 AM Thread Starter
RCFEY's Avatar
MY SRW VS MY DRW
hello, I am new to the site, was wondering if anyone could help me out? I have a 2000 f350 7.3 SRW and just bought a 2000 f350 DRW, both have same exhaust/air/superchip (on same setting) and my dually does not run near as hard?? No work has been done to either motor or tranny. any ideas would be appreciated. thanks
RCFEY is offline
post #2 of 3 Old 08-19-2013, 10:09 AM
alaskan155's Avatar
Quoted: 60 Post(s)
whats the gearing on them? they both could have different axle ratios on them, you can find the ratio by looking at the tag on the axle or the axle code on the white drivers side door jamb sticker
2002 F250 7.3/JW Tow master 4r100 210k miles
Mods:explorer heater valve, WR GP relay, RiffRAff boots, lariat overhead console, Hydra chip, 6637 mod, 6.0 cooler, AIH delete and isspro2 trans, egt, and boost gauges. 92 gallon aux tank with a total capacity of 130gallons, 1800 mile range
, 4" MBRP straight Piped. 2" Warrior shackles
alaskan155 is offline
post #3 of 3 Old 08-19-2013, 10:49 AM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
Chances are your gearing is different but also its got a bigger arse on it so its a bit harder to move than a SRW
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
