1999 F350 FRONT END CONVERSION - Ford Powerstroke Diesel Forum
post #1 of 4 Old 06-29-2013, 10:08 AM Thread Starter
Exclamation 1999 F350 FRONT END CONVERSION
Hello Everyone,
First of my name is Yves, and it's a pleasure to join you all in this forum!
Now to the important stuff, I am having a frustrating issue with my 1999 F350.
I have searched for a similar situation in the forum but did not find one.
So the previous owner decided to do a front end conversion with parts from a 2006 f250... And I bought it this way, but it seems that the front bumper will not fit on right, he had some strange bolts holding it together and it was a bit off. The corner ends of the bumper were not lining up with the fender and the lights, they were instead raising above the fenders. So I took the bumper off and put it back on with the original bolts. But the bumper is still having the same issue. I am not sure if its the bumper that it not the right fit for my truck, or its where the bumper is hooked up to... Please help, I would like to do this myself if I could, since I just dropped $800 on other things that the truck needed...
Thanks
ID:	131930   Click image for larger version
ID:	131938   Click image for larger version
yvesm19 is offline
post #2 of 4 Old 06-29-2013, 10:21 AM
I am not familiar with the 05+ parts on 99-04.
Usually its a direct bolt on process I thought. I hope the bumper is not tweaked or anything. Does it still use the braces on the inside corners of the bumper?
Maybe a shim is needed on the bottom bolt where it mounts to the frame. Hopefully others with experience can help. That would drive me crazy.
03 F350 7.3L Auto CC LB Dually 410's (LS Rear)315's
PHP/Beans tuned, 250/100 FF inj's, BTS Tranny, Strictly Diesel complete fuel system w/RR & FB Delete, Pius LASB from Irate, Swamps hvhf IDM
Autometer Nexus Guages (TT,FP,BP,EGT), 4"MBRP, DieselSite Coolant filtration system/billet housing/HP X-Over line, Baldwin PA2818(6637) RR Boots, 26 row 6.0 Tranny & PS Cooler, LarryB's Denso Starter
INFRNL is offline
post #3 of 4 Old 06-29-2013, 10:38 AM Thread Starter
see att. pics..
ID:	131970   Click image for larger version
ID:	131978   Click image for larger version
yvesm19 is offline
post #4 of 4 Old 06-29-2013, 10:38 AM Thread Starter
I am not sure, to be honest, I thought it would fit on too, but lets not forget it came from a 250 not a 350...
yvesm19 is offline
Tags
bumper , conversion , f250 , f350 , front end
