Biggest tire - Ford Powerstroke Diesel Forum
post #1 of 6 Old 06-25-2013, 09:01 AM Thread Starter
Motor Head.
robertc68's Avatar
Quoted: 39 Post(s)
Biggest tire
What's the widest 17 in tire that will fit a without problems or needing spacer? Currently I have 16 inch rims stock width tires but plan on putting 17 inch alcoas, but want a wider tire, not taller .
04 350 DRW CC LB,4:10,245/75/17,tires 4X4..Coolant filter. CTS.Stage II AFE.EGR Delete,Zoodad ,regulated return, ,Arp,OemHG,AD150,WPE ported int,58FICM,190/30 Injec,05 coil conversion.WPE/KC 1.5 turbo,2011 rear leafs,13 tailgate,flight fab trac bars.2014 Power/folding/Extend mirrors.
robertc68 is offline
post #2 of 6 Old 06-25-2013, 11:00 AM
What do you plan on doing about the steel wheels? I do not think anyone makes a 17in steel wheel with the 8x170 bolt pattern unless its custom.
You cannot go much wider than stock without a spacer. Plus I dont think you can get much wider without going taller. Maybe a 10.5 wide tire. The 16in version I believe is the 265 iirc.
I'm sure others with more experience will chime in to help
03 F350 7.3L Auto CC LB Dually 410's (LS Rear)315's
PHP/Beans tuned, 250/100 FF inj's, BTS Tranny, Strictly Diesel complete fuel system w/RR & FB Delete, Pius LASB from Irate, Swamps hvhf IDM
Autometer Nexus Guages (TT,FP,BP,EGT), 4"MBRP, DieselSite Coolant filtration system/billet housing/HP X-Over line, Baldwin PA2818(6637) RR Boots, 26 row 6.0 Tranny & PS Cooler, LarryB's Denso Starter
INFRNL is offline
post #3 of 6 Old 06-25-2013, 11:20 AM Thread Starter
Motor Head.
robertc68's Avatar
Quoted: 39 Post(s)
Well long story short, I am putting stock 05 and up steel rims on back.i am converting the front axle to 08 coil spring.For the back axle I am getting adapters that will get me to 8x200 pattern.
post #4 of 6 Old 07-13-2013, 03:48 PM
The Silent Service
colo_dually's Avatar
Quoted: 10 Post(s)
Widest I'm familiar with here is running 265/70R17 without the need for any spacer, and not affecting your ability to tow at full capacity. Basically the same height as the stock 245/75R17s from the '05+ DRW trucks.
2007 F-350 XLT 6.0L PSD Dually 'Jezebel'
TorqShift 4x4 CC/LB 4.30LS - Tow Boss Package
colo_dually is offline
post #5 of 6 Old 07-15-2013, 08:07 PM
countryraised's Avatar
I have 265/70/17's and I would not want to try 285's without a spacer. would actually rather try a 255/80/17's, a little narrower but taller.
Vince
John Deere product developement
FOR SALE '99F350 2008 F350 mini maxx'd
countryraised is offline
post #6 of 6 Old 07-16-2013, 04:50 AM Thread Starter
Motor Head.
robertc68's Avatar
Quoted: 39 Post(s)
Ok thanks.
