Single wheels on a dually axle? - Ford Powerstroke Diesel Forum
post #1 of 24 Old 06-14-2013, 04:05 PM Thread Starter
I know there are many reasons not to put dually wheels on a SRW axle. Can I go the other way? Last time I had a dually, I really didn't like driving it in the snow. And I rarely tow in the snow, anyway, so there's not the need for the added weight carrying capacity. If I swap in a dually axle, will I be able to run single wheels in the winter?
BrownianHeatingTech is offline
post #2 of 24 Old 06-14-2013, 05:12 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
What kind of truck do you have? And if you run a single wheel you would have a lot of fender space
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 24 Old 06-14-2013, 05:42 PM Thread Starter
2002 F350. Currently has a utility body, but I'm looking at swapping over to a flatbed, and I'd only do the dually conversion if I did that.
post #4 of 24 Old 06-14-2013, 05:49 PM
I've seen people run with the outer dual off in the winter, But havent seen single rims run on a DRW axle.
cantrun10s is offline
post #5 of 24 Old 06-14-2013, 05:58 PM
It can be done both front and rear. It may look a bit funny though depending on wheels and tire size. Depending on the look your after, you may want a spacer in t he rear
03 F350 7.3L Auto CC LB Dually 410's (LS Rear)315's
PHP/Beans tuned, 250/100 FF inj's, BTS Tranny, Strictly Diesel complete fuel system w/RR & FB Delete, Pius LASB from Irate, Swamps hvhf IDM
Autometer Nexus Guages (TT,FP,BP,EGT), 4"MBRP, DieselSite Coolant filtration system/billet housing/HP X-Over line, Baldwin PA2818(6637) RR Boots, 26 row 6.0 Tranny & PS Cooler, LarryB's Denso Starter
INFRNL is offline
post #6 of 24 Old 06-14-2013, 07:02 PM Thread Starter
It's a work truck, so looks aren't that important. I'm mostly concerned with whether it will cause any mechanical problems.
post #7 of 24 Old 06-15-2013, 08:21 PM
There won't be any issues
INFRNL is offline
post #8 of 24 Old 06-16-2013, 06:06 AM Thread Starter
So, with the truck being a 2002 F350 with 3.73 gears and ABS, which dually axles will fit?
post #9 of 24 Old 06-16-2013, 11:22 AM
I saw a truck pulling at the fair. it was a dually with regular rims. the back rims looked 14 inches wide with some fat rubber out back. i fell in love with the look.
2006 Ford Powerstroke Super Cab 4x4 auto 120K bulletproofed
ramz trk is offline
post #10 of 24 Old 06-17-2013, 08:56 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Well the dually from 99+ uses a Dana 80, where as a srw truck has a sterling 10.50, so I doubt there is a difference in spring perch width, but you will just need to find a dually rear with 3.73 gears 99-04 to retain the same bolt pattern, or just put a spacer on the rears
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
The Following User Says Thank You to 351fifty For This Useful Post:
N2dafog (11-16-2013)
