Go Back   Ford Powerstroke Diesel Forum > General Topics > General Diesel Discussion > Dually Discussion
Old 03-19-2008, 08:13 PM
HVAC SuperTech HVAC SuperTech is offline
Scott loves the Squirell
Temp. DRW to SRW to save on fuel?
I was wondering, could you remove the inner wheel in the back to save on fuel cause you wouldn't be turning so much mass? I dont haul often enough to need the dually all the time. most of my driving is around town on the weekends, and some trips when I go to training for work, but nothing to do with weight. If I was gonna haul weight, I could put the inner two back on. Whats your guys thoughts?
Old 03-19-2008, 08:34 PM
dhanna6powerstroke dhanna6powerstroke is offline
Got Smoke?
Not going to save you enough fuel to counter act the look! Don't mean that as an insult. I would just leave them on and make sure the tires are at the proper inflation.
Old 03-19-2008, 08:37 PM
Tikal Tikal is offline
Thas how we do'r in Dixie
Send a message via AIM to Tikal
I guess you could if you really wanted to. I don't think that you'd really see that much of a difference in mpg though.
Old 03-19-2008, 08:45 PM
Peppy Peppy is offline
bad idea due to the offset of your rims this will put lots of stress on wheel studs bearings and housing, the only way to safely do this is to buy rims with the proper offset.
Old 03-19-2008, 08:47 PM
Gotcha. I was thinking about the looks and the stress on the studs too. They will stay...Thanks guys
Old 03-19-2008, 08:48 PM
bad idea as this puts lots of stress on wheel studs, bearing and rear end, if you still want to run srw you'll have to get rimswith the proper offset.
Old 11-21-2008, 08:52 AM
RX-Kevin RX-Kevin is offline
I run a dually outer wheel and havn't had a problem yet
Old 11-21-2008, 09:02 AM
scotty2280 scotty2280 is offline
why did you get a dually if you dont haul alot? not trying to be mean just wondering
Old 11-22-2008, 04:28 AM
It was a great price and I wanted a dually so I could haul my mustang to the track.
