should be able to get lots of advice on this subject? - Ford Powerstroke Diesel Forum
post #1 of 2 Old 06-09-2013, 11:54 AM Thread Starter
Quoted: 4 Post(s)
Cool should be able to get lots of advice on this subject?
Okay, best plan of attack for mountain driving, towing 5 tons? What is a good RPM to maintain on climbing grades so as not to overheat things? What about going down the other side of the mountain? I have an E40D tranny, does it have a retarder???? If the downgrade is more then a mile long should I keep the tranny in 2nd gear? I'm asking because I've never towed my 5th wheel in the mountains and have never towed through the mountains using a diesel truck. Leaving tomorrow from Vegas to Portland Oregon by route 95 to 395. Thanks all who respond.
timlsalem is offline
post #2 of 2 Old 06-09-2013, 12:01 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
It's important to keep the boost up going up the hills, this keeps the egt's down, but hauling up steep grades I was running 45-50 mph, at 1200* and 15 lbs of boost at around 2400 rpm, in 3rd, had to eventually drop to 2nd to maintain 35-40 mph, without cooking my turbo, going down just hit the od off to keep your speed low to keep the trailer from pushing you down the hill
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
