New here. - Ford Powerstroke Diesel Forum
post #1 of 11 Old 05-29-2013, 07:05 AM Thread Starter
New here.
Looking at an 01 F350 Crew/Dually, 7.3 w/345k on the odo. Truck is in overall good condition. Asking price was $10k, have them down to $7.5k Is this a good deal?
sigguy is offline
post #2 of 11 Old 05-29-2013, 09:22 AM Thread Starter
Here is a photo of the truck.
sigguy is offline
post #3 of 11 Old 06-01-2013, 02:35 PM Thread Starter
or an 04 F350 CC Dually 4x4 w/175k on the odo and the 6.0L for $8500.-
sigguy is offline
post #4 of 11 Old 06-01-2013, 05:56 PM
jaysshortbus's Avatar
Jay
jaysshortbus is offline
post #5 of 11 Old 06-01-2013, 08:49 PM
I would personally go for the 01 because of the 7.3l. The 04 would take a few thousand to put into it to help make it less troublesome. There are a lot of guys that have the 6.0l with and without issues. I would make sure everything is ok on the 01 though. Depending on its history 375k mi could be ok or bad. I would definitely have it gone through real well.
03 F350 7.3L Auto CC LB Dually 410's (LS Rear)315's
PHP/Beans tuned, 250/100 FF inj's, BTS Tranny, Strictly Diesel complete fuel system w/RR & FB Delete, Pius LASB from Irate, Swamps hvhf IDM
Autometer Nexus Guages (TT,FP,BP,EGT), 4"MBRP, DieselSite Coolant filtration system/billet housing/HP X-Over line, Baldwin PA2818(6637) RR Boots, 26 row 6.0 Tranny & PS Cooler, LarryB's Denso Starter
INFRNL is offline
post #6 of 11 Old 06-02-2013, 06:03 AM Thread Starter
The 04 6.0L is a one owner. Purchased locally 7/04, transmission replaced by Ford 10/05, Torque converter solenoid replaced, trans pan gasket replaced, EGR valve replaced 6/06, regular service performed by Ford. This info. is reported by CarFax. Pulling an Oasis report tomorrow from the dealer that sold it new and performed most of the repairs/maintenance.
sigguy is offline
post #7 of 11 Old 06-02-2013, 09:49 AM
RIP Cam!
Rattlesnake18's Avatar
Quoted: 1011 Post(s)
Feedback Score: 6 reviews
to the ORG
2004 F250 CC Lariat 4x4
BPD FICM, BPD billet water pump, BPD VK688 oil cooler kit, S&B CAI, MTW stage 2, TSD tunes, Auto Meter gauges, Edge CTS, Sinister coolant filter, Blue spring, 6.4 banjo bolts, Straight piped w/ 6" single mitre stack, Pro Comp leveling kit, 05-07 HD headlights, Xenon-Vision 5k HIDs, Fumoto block drain valves, ELC, High idle mod
Originally Posted by djmaguire View Post
I'm guessing that you didn't lose nearly as much as it appeared. Spills are like that. The last beer that I spilled was like a million ounces.
Rattlesnake18 is offline
post #8 of 11 Old 06-02-2013, 11:28 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Find out the oasis, but the 6leaker has half the miles, they really are a great motor, but sometimes they fail often, just something to think about, the 7.3 is not known much for a fail, but the do still anyway, and with those miles I would be Leary, and I buy trucks barely north of 300k, would never buy something past 350, that's to much of a risk unless I have enough cash to buy a spare engine too, not everything gets done at shops, and not everyone is COMPLETELY honest
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #9 of 11 Old 06-03-2013, 04:57 AM Thread Starter
Thanks 351
sigguy is offline
post #10 of 11 Old 06-03-2013, 05:22 AM
MyTractorsSexy's Avatar
Quoted: 7 Post(s)
id roll with the 6.0 and let it go till it breaks then stud it. international recommends a rebuild on the 7.3 at 350K miles so its basically time or you can run it and just see how it goes... i would definitely have that 7.3 or the 6.0 gone through pretty tough either way.
Mild build 07 F250-SOLD
2011 Black CC SB Lariat F250, 2015 Retrofit, MPD IC Piping, H&S Mini Maxx custom tuned, 5"Flo-pro Exhaust, Sininster Egr Delete, Recon Lighting, No Limit S2 Intake, Tinted, BDS 8" 4-Link Lift w/ Fox Shocks & Dual Steering Stabilizer, 4.10 Yukon's with electric lockers, 37/13.50/22 Toyo MT, 2-Piece Fuel Maverick 22x12 Wheels, PTM Grille Surround, T REX X-Metal Grille, LED heads and fogs, kenwood double din, 4 hertz 210W door speakers 2 JL TW3 10s kenwood amps.
MyTractorsSexy is offline
