Go Back   Ford Powerstroke Diesel Forum > General Topics > General Diesel Discussion > Dually Discussion
Old 03-06-2008, 07:53 AM
Cumminskiller2007 Cumminskiller2007 is offline
2000 7.3
anyone know how to turn up the fuel on a 2000 f-350 7.3?
Old 03-06-2008, 08:02 AM
stroker27 stroker27 is offline
i dont think you can turn it up, i think its controlled by the pcm. you can chip it though, and tell the computer to turn up the fuel
Old 03-06-2008, 08:20 AM
I was told u could but its a pain to do it, im just wondering how u do.
Old 03-06-2008, 09:22 AM
RWML2 RWML2 is offline
check around on some other topics. i have seen 2 so far. one was with a BB and another using a bolt in the fuel pressure regulator at the fuel filter. if i can find it again i will link it for you.
Old 03-06-2008, 10:24 AM
OK found the link
OBS FPR Shim and Gauge Install
be sure to use a guage. this is the BB mod and i have heard of people pushing over 100 psi and blowing seals out.
hope this helps
Old 03-06-2008, 10:35 AM
is that the same set-up as the 2000? it looked a little different to me
Old 03-06-2008, 10:49 AM
Sorry your right that is PRE-99
Old 03-06-2008, 12:21 PM
so no one knows how to turn it up on a 2000
Old 03-06-2008, 01:16 PM
MrJohnWayne MrJohnWayne is offline
Thats Mr. Oil Leak.....
same principle. you still add a shim/bb to the fuel pressure regulator.
Check out this link: Fuel Regulator Shims pictures from cars photos on webshots
Old 03-06-2008, 01:19 PM
Mavsps Mavsps is offline
Its not going to give u much difference tho. Should gain a few ponies but nothing like a chip
