Any tips, tales or takes on the new F450? - Ford Powerstroke Diesel Forum
post #1 of 16 Old 05-08-2013, 07:15 PM Thread Starter
Trailer Park Casanova's Avatar
Our dealer just sent us some serious info on the F450 and the 2014 will be avail for order late June. We'll probably pull the trigger.
Gleaning the forums,, seems that beyond some teething pains, the 6.7 PS may be good to go.
Seems Ford is seriously backing up service too.
We ordered a new 43' 5th wheel, 18.000 lbs and the F450 is just the truck for it.
I dunno about you,, but it calls out to me to buy it.
-or,, is the F450 overkill and a srw the better way to roll?
Will we still have to bag the F450?
Am I making a deal with the devil or is the 6.7 a good motor?
Are the brakes and ride quality really improved over the first year F450?
What can we expect for MPG towing?
Are the 20" wheel with the platinum pkg good to go, or will we have limited selection on replacement tires when that time comes around?
Finally,, can anyone recommend an aux fuel tank? Bed mounted is fine. We need range.
Appreciate for any tips tales or takes.
Trailer Park Casanova is offline
post #2 of 16 Old 05-08-2013, 07:17 PM
Quoted: 2 Post(s)
Can't really say much for the truck as I have not driven a 2014 yet, but Titan makes sweet in bed plastic fuel tanks that lock and install easy.
Troy K.
2003 Ford F-250 6.slow w/240K
4" Turbo back exhaust
SCT X4
XDP coolant filter
Blue Spring
315/75 BFG MT's on American Racing rims
Leveled
5100's
And way more time and money invested than its worth
Turk.919 is offline
post #3 of 16 Old 05-08-2013, 10:01 PM
F450Harley's Avatar
The fifther you have, 18K lbs dry weight.......plus another 4K-5K lbs (depending what you re loaded with) can be pulled by a SRW too.
Now if you compare that to being pulled with a dually (esp 450) its like night and day.
The 450s are the hauling kings.
If im going on long trips with that kind of weight, I would only consider a dually.
Its always good to have more rig than you need for the load.
As far as MPG I have not even bothered to look at, but Id be surprised if I grt any better than 9-10 mpg towing heavy.
I got 4.30s in the rear. Some others come with 4.88s (less mpg @ same speed).
The trick is: Be easy on the pedal (esp on take offs), anticipate the traffic & coast it instead of using the brakes, top speed should be 63 mph.
I hate these rules btw. Ha ha.
Remember......this is a 6.4L insight.
You re going for a 6.7L.......witch I think it wont be much different.
The difference would be the 6.7s are even better.
Title on hand like always
F450Harley is offline
post #4 of 16 Old 05-08-2013, 10:15 PM
Fantom's Avatar
Quoted: 11 Post(s)
Feedback Score: 4 reviews
I wouldn't think with that kind of weight you're want to be running a SRW truck. Sounds to me like that trailer is just the job for a 450.
John
2004 Harley Davidson F250 #1191 - 6.0 Powerstroke
Studded - Lots Of Bulletproof Diesel Parts
Swamps 58v FICM - KC Stage 2 Turbo
Ported Intake - S&B CAI
100,000 Miles
Live in Northern California? Stop in here and say hi
Fantom is offline
post #5 of 16 Old 05-08-2013, 10:26 PM
I just bought a 2012 f350 dually. I had a pretty good deal lined up on a 450, but insurance cost was going to be an additional $1000 a year for the 450.
I would definently look into insurance cost before you buy.
Also for that much weight you need to look into a dually. Your main limiting factors will be GCWR and Payload capacities. The SRW have a GCWR of around 23500 and the 350 6.7 dually's have a GCWR of 30,000.
Based on the length and weight of the trailer you speced above it sounds like you are getting a Mobile Suites 5th wheel and those typically have a pin weight of 4,000+. You will need to definently pay attention to your pin weights. You probably will not have issues with your Rear axle rating, but make sure your tires are rated for more than your RAWR.
Also on the 350 and 450 dually's you get 17" wheels not 20". The 6.4's had 19.5" wheels on the 450's but that has changes.
Good luck with the new truck and RV purchases. I just went through all of this. Bought the RV 2 weeks ago and bought the new truck 2 days ago.
bcaggie07 is offline
post #6 of 16 Old 05-08-2013, 11:05 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
I vote dually as well, way more stable in every situation, beyond comparison, and the 450 is a lot of truck
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #7 of 16 Old 05-09-2013, 05:51 AM Thread Starter
Appreciate the tips and tales.
We just Lemon-Lawed a 32' 5'r that we towed with our srw GMC 2500HD 8.1 gas rated at 13.000 lbs 5th wheel towing.
Very capable but best mileage was 6.1 MPG with about 24 usable gallons in the tank.
So,, travelling around the USA we were looking for a gas station every 2 hours on the road. That's crazy really. Too much. Just nuts.
So diesel with extra capacity tank is they way we want to roll.
I had no idea the registration on a F450 would astronomically higher, I'll look further into that. I had heard something that a home owner registration is different than if the truck is used for business,, but that could be a sea story.
We bought a new Z06 and the registration in Cali on that is $1000 each year, insurance is $1000 per year too. Crazy I know,, but it's a new era I guess.
The Lemon Law ordeal on our 5th wheel lasted 4 years and we dealt with 3 different law firms. That's a normal flow for this kinda deal. I asked each firm what tow vehicle they would buy and hands down they all recommended the Ram. "We never ever see any Ram cases come into the office" they told us. "We'll never see you again".
We've had horrific experiences with Dodge/Rams dealers in the past. We and our friends Rams always seem to need brakes and are seriously falling apart, collapsed dashboards, loose steering columns, so we're not getting bit by that dog twice.
They are nice looking,, but not going through that hell again with a Dodge service dept.
Neighbour down the street bought a new F450. It was beautiful and just the base model. Before I could ask him about it, he sold his place with a 3 day escrow, stuck the key in the ignition,, and moved off to Sandpoint Id.
Thanks for the takes, we'll roll by the dealer or AAA and get a fix on the DMV cost and insurance issue and keep a close watch if the 6.7 starts acting up.
post #8 of 16 Old 05-09-2013, 08:23 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
In California I'm told they are registered as commercial unless a topper is over the bed, and I would still only buy a ford, only good thing about a dodge is they out sourced a diesel to cummins
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #9 of 16 Old 05-09-2013, 10:40 AM
I've done quite a bit of long hauling and a dually is the way to go. The stability alone is worth it. I've also found out that airbags are a good thing to have, so I'd recommend a set of those as well. Have fun!
bigbert007 is offline
post #10 of 16 Old 05-09-2013, 07:22 PM
tkobes43's Avatar
Quoted: 2 Post(s)
Garage
The 450 is definitely the way to go with that sized trailer... But check with insurance before you place the order!
Tom
5" MBRP Straight Exhaust w/ 6" tip, SCT Monitored, Limo Tints, 20" LED Lightbar, 8k HIDS, & Some other goodies
Other Rides
1978 Trans Am Y88 403 84k original miles
1996 Ford F350 PSD Mason Dump 134k Original Miles!
Gone But Not Forgotten... (Lilah) 2008 Ford F250 Lariat CrewCab
Proud To Be An American!
tkobes43 is offline
