I think my rear end is going - Ford Powerstroke Diesel Forum
post #1 of 4 Old 04-29-2013, 08:45 PM Thread Starter
I have a 2003 F350 Dually. I have a howl coming from the rear end, it seems to go away after a it warms up. My question is, how bad is this? and will it just blow or will it just keep making more and more noise?
I noticed just before I moved to Manitoba that it was low on fluid, I topped it up and by the time I arrived here, the fluid was leaking out of the axle seals, I have changed them, and its topped up. but I think the damage is done.
Msmadison is offline
post #2 of 4 Old 04-30-2013, 03:53 AM
jaysshortbus's Avatar
Talking
My rear end howls after chilli !!!!!
Jay
jaysshortbus is offline
post #3 of 4 Old 04-30-2013, 06:24 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Mine does after coffee and a cigarette
Did you pull the cover to inspect it?
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #4 of 4 Old 05-31-2013, 09:13 PM
countryraised's Avatar
Does it change sound based on load? If you let it go you will have metal shavings in the oil and more damage will continue.
my 08 was the pinion bearing going out, was less noticable costing, more when slightly accelerating or under load, goin up a hill. You need some big wrenches and possibly a rear case spreader to get carrier section in and out easily, can be done without(i did) but not easy.
Vince
John Deere product developement
FOR SALE '99F350 2008 F350 mini maxx'd
countryraised is offline
