Yet Another SRW to DRW conversion question. - Ford Powerstroke Diesel Forum
post #1 of 11 Old 03-25-2013, 06:00 AM Thread Starter
upd103's Avatar
Send a message via Yahoo to upd103 Send a message via Skype™ to upd103
OK. Sorry, but I've searched, so I'm going to throw it out there anyways.
I am exploring the possibility of converting to DRW as the title says. Right now, I'm not towing anything real heavy, but we are about to increase the size of the horse trailer to a full living quarter trailer.
My question is this. I am not looking to drastically increase the weight rating of the axle or capacity, but I am just looking for more stability when we get the new trailer. I've pulled Full LQ horse trailers before, and you can definitely feel a little sway back there going down the road.
My options are obviously to find a Dana 80 and get the larger capacity and brakes etc, or I can just do wheel adapters. I'm thinking that the adapters will be just fine for my needs since I'm already in a 1 ton, and I'm not looking at having a ton of weight on it. If I go full D80 then I'm gonna have to re-gear the fronts too since I'm not a 4.10 right now. I'm thinking it's going to just be more trouble than it's worth.
As for the bed, I'm just going to go with a full skirted flat bed since it will be more practical for me any ways. So selling the factory bed will get me close to that replacement.
Do y'all agree that the adapters are likely the best choice for my needs, or am I completely off with my thinking and need to be put in check? LOL
Thanks in advance and God bless,
-David
-David-
upd103 is offline
post #2 of 11 Old 03-25-2013, 06:07 AM
Jerzyperson's Avatar
Re: Yet Another SRW to DRW conversion question.
Does your truck have the sterling 10.25? Or is it a d60 rear?
Jerzyperson is offline
post #3 of 11 Old 03-25-2013, 06:13 AM Thread Starter
upd103's Avatar
Pretty sure it's the 10.25". But I'm in Afghanistan, and I can't check for sure til I get home.
I thought all the 08-10 SRW 350's had the 10.25 in them. Am I wrong there too?
****EDIT
Actually, I'm reading it's the 10.5" now. Upgraded from the 10.25"
-David-
upd103 is offline
post #4 of 11 Old 03-25-2013, 06:22 AM
Which means your rear axle is bigger then a d80. I wouldn't do any converting. These sterling axles are bullet proof. I have the 10.25 and I pull horse trailers all the way up to flatbeds with vehicles on it. Just food for thought. You wouldn't have a problem selling that sterling if you do. Most off road, mud, or crawler guys kill over sterlings.
post #5 of 11 Old 03-25-2013, 06:25 AM Thread Starter
upd103's Avatar
OK. Well the 10.5" and spacers it will likely be then.
You think I'll be giving up much strength with the spacers? They will definitely be the weak link at that point I think.
I'm not worried about the spacers in the front since that's how the factory gets the width. Just worried about how much strength I lose widening the rear a couple of inches.
-David-
upd103 is offline
post #6 of 11 Old 03-25-2013, 09:45 AM
Tj Krawler's Avatar
I'll throw in my opinion.
Don't cheap out. Do it the right way, I think it will be easier in the end. And if you ever sell it, I think you would be able to get more of your money back.
OBS trucks had the 10.25 rear
SD trucks have the 10.5
DRW trucks have the Dana 80
The Dana 80 is the heaviest of the 3 axles. If you're lucky, you could find one with 3.73s in it already.
Where I think you might run into a problem just throwing spacers on the SRW axle is that the Dana 80 is 1.5" or so wider to start with. I don't think it would cause a tire to rub anywhere, but it might. If you're getting a flat bed built I think it would be ok. After all, the cab/chassis trucks rear axle was even shorter. I don't know by how much though.
If you decide to keep the SRW axle and use spacers. Don't buy cheap spacers. There are quite a few on here who will only use Fred's spacers. When I get spacers, I will get mine from him. WheelAdapter.com Don't forget to add the cost of shipping... For me it would have been over $70. In your case, buying a Dana 80 might work out to be the same price, but you end up with a stronger axle.
Alan
2000 F-350 CC LB DRW 4x4 XLT Auto
- Intake
- Exhust
- ScanGauge
Tj Krawler is offline
post #7 of 11 Old 03-25-2013, 10:00 AM Thread Starter
upd103's Avatar
OK. Thanks for the information. And Thank You very much for Fred's link. I guess I will hit up Pick a Part when I get back Stateside and see what I can find. Hoping brake lines and the majority of the small stuff will not be much of an issue.
Thanks
-David
-David-
upd103 is offline
post #8 of 11 Old 03-25-2013, 10:31 AM
Tj Krawler's Avatar
Thanks
-David
No problem.
I have not heard of the brake lines being a problem. As far as I know, the spring mounts should be a direct bolt in. Unless you get a C&C axle.
EDIT: Make sure you match the axle bolt pattern to the front if you do go with a Dana 80. They changed from 8x170mm to 8x200mm in '05. I think the '08s are 8x200mm as well.
Alan
- Intake
- Exhust
- ScanGauge
post #9 of 11 Old 03-25-2013, 12:18 PM
tkobes43's Avatar
Quoted: 2 Post(s)
Garage
Good luck on the build!
Tom
5" MBRP Straight Exhaust w/ 6" tip, SCT Monitored, Limo Tints, 20" LED Lightbar, 8k HIDS, & Some other goodies
Other Rides
1978 Trans Am Y88 403 84k original miles
1996 Ford F350 PSD Mason Dump 134k Original Miles!
Gone But Not Forgotten... (Lilah) 2008 Ford F250 Lariat CrewCab
Proud To Be An American!
tkobes43 is offline
post #10 of 11 Old 03-25-2013, 05:18 PM
F350R's Avatar
Quoted: 10 Post(s)
Maybe just put a set of 19.5 rims and tires on what already have. That will also give you a lot of stability with G or H rated tires. I recently replaced the worn out 245x70x19.5 G rated tires with 265x70x19.5 H rated tires. Other than being taller there's no ride quality difference. I also replaced worn out Bilstein shocks and installed a 2.5 leveling kit. 19.5 tires are not cheap but they are very stable and wear a lot longer that the smaller tires.
2004 F-350 CC LB Lariat FX4, SCT Erics Street tune, BPD EGR Cooler, BPD oil cooler, Empty CAT, Snows Water / Meth, Coolant & Oil bypass filters, 265x70x19.5 on American Force wheels, On board air system, Firestone air bags in cab regulator, dual air horns
F350R is offline
