Need help finding Aftermarket rims - Ford Powerstroke Diesel Forum
post #1 of 6 Old 03-24-2013, 04:44 AM Thread Starter
So I'm soon going to be lifting my 01 dually 6in front and back. I've been searching for new rims and I'll I come up with are aftermarket 16x6 rims on like ebay or tire rack. Or I found American force. Ima college kid so American force is out of the question. With that said where can I find some like 17 or 18 in dually rims? I want some wider rims to for bigger tires. Also what the biggest tire I can fit on my stock rims? I'm not overly familiar with tire fitment. Do I have to worry about the with of the tire with a 16x6 rim? Thatnk
Sent from my VS930 4G using AutoGuide.Com Free App
01 F350 dually CCLB Lifted 7in
WW Gen2
6637 w/zoodad
6pos tuner canned tunes
isspro ev2 pyro, boost, trans temp
4.5" custom stack
AIH delete
CCV mod
22.5 rims on there way
ventryjr is offline
post #2 of 6 Old 03-24-2013, 08:51 AM
Take a look at the fatbottom thread or lifted dually thread. Most guys have stock wheels running 12.5 wide tires. If your're ok with the look, then your golden. It would definitely be nicer to run a wider wheel but you will have a hard time finding them for the 8 on 170 bolt pattern.
This is one downfall to our trucks, lack of wheel selection especially wider than 6". What size tire were you planning to run? I know you can get a 255/85/16 BFG MT which is a 33x10.50 I believe.
As far as wear, most do not seem to have many issues. Take a look at the threads I mentioned. We recently brushed over tire wear in the fatbottom thread
03 F350 7.3L Auto CC LB Dually 410's (LS Rear)315's
PHP/Beans tuned, 250/100 FF inj's, BTS Tranny, Strictly Diesel complete fuel system w/RR & FB Delete, Pius LASB from Irate, Swamps hvhf IDM
Autometer Nexus Guages (TT,FP,BP,EGT), 4"MBRP, DieselSite Coolant filtration system/billet housing/HP X-Over line, Baldwin PA2818(6637) RR Boots, 26 row 6.0 Tranny & PS Cooler, LarryB's Denso Starter
INFRNL is offline
post #3 of 6 Old 04-01-2013, 06:12 AM
you will not find wider wheels than 17x6.5 unless you step up to 22" or have a custom set made. i run a 12.5 tire both front and rear. in the back you need a 2.5 spacer so the tires dont rub. i didnt like the look on the front so i switched out to a standard 17x9 wheel and ditched the dually spacer. the aftermarket for dually wheels is slim
06 f350: 8" ICON 2.5 resi's, ouo ala's, pmf track bar, dual stabilizers, custom 5" exhaust, 37" BFG km2's, 4.30s, 08 tailgate w/step, 08 tail lights, coolant filter, BPB oil cooler w/p 58v ficm and radiator, ARPs, 175cc, MTW s1 billet, ported intake, egr delete, onboard air and gearhead tunes
All the above just to haul the 900hp street mustang
94slowbra is offline
post #4 of 6 Old 04-06-2013, 06:53 PM Thread Starter
I'm lifting my truck 6in. And i have a custom front bumper so no rub there. And I'm ok with fender trimming. I was thinking something like a 38x10.50? That seem realistic with this set up? And I plan on spacers in rear. Thanks.
WW Gen2
6637 w/zoodad
4.5" custom stack
AIH delete
CCV mod
ventryjr is offline
post #5 of 6 Old 04-06-2013, 07:21 PM
Do they make a 38x10.50? Those would fit the narrow dually wheels. Slobra did a good job matching his wheels. While not perfect, damn near.
I was going to go with 17's but didn't have any luck finding a steelie for our bolt pattern. I'm just going with eagle 058's with 16x10 in front. A lot of people do not like that Alcoa kind of style but I do. I also wouldn't mine trying to find some 5 stars that match the oem, but I do not think I have seen any that match well.
INFRNL is offline
post #6 of 6 Old 04-09-2013, 06:14 AM
Try rickison wheel manufacturing they make good 19.5 in rims and tiresa
Sent from AutoGuide.com App
Powerstroker25 is offline
