driveline vibration 2011 F350 dually with 10" lift - Ford Powerstroke Diesel Forum
post #1 of 2 Old 03-13-2013, 11:48 PM Thread Starter
Those of you with lifted dually CC LB's what are you using for a rear driveshaft. I lifted my 2011 F350 dually CC LB 10 inches and no matter what I do I can not get rid of this driveline vibration. So far I've tried rotating the pinion up 5 degrees, a custom 1.5 inch transmission drop mount, completely rebuilding the driveshaft and of course shimming the the carrier bearing and nothing seems to help. After doing all that I looked into getting a one piece drive shaft made but no local driveline shop will build me a one piece that long. Some of the guys over on the cummins forum with similiar issues seem be getting away with a one piece without any issues. I am completely at my wits end with this issue. Anyone here have any ideas?
2013 F150 SuperCrew Lariat 4x4 6.2L
Flowmaster catback dual exhaust
6" BDS lift w/ 1.5" Daystar leveling kit, 335/65/R18 Nitto Terra Grapplers
2011 F350 King Ranch Dually 4x4 Diesel
8.5 Skyjacker 4 link Lift w/ 2" leveling kit, 40X13.50 Nittos
2010 Shelby GT500 Coupe
Black/grey stripes
2.3L Eaton S/C, JLT CAI, 65mm CJ TB, Injector Dynamics 725s, JBA offroad exhaust, AFCO dual fan H/E
sask08 is offline
post #2 of 2 Old 03-17-2013, 04:34 PM
sulltran's Avatar
When I put the 20" lift in mine i ditched the 2 piece shaft for a custom 1 piece with a high angle cv on the transfer case side. I know there are critical length measurements you are not supposed to go beyond. I was close to max length with my supercab dually. You will have to keep the 2 piece , i believe, but it can be made to run vibration free. My truck had a little shudder on takeoff when stock with the 2 piece....and absolutely smooth a silk at all speeds with the 20" lift and the custom shaft with cv joint. I ordered mine from High Angle Driveline out in CA and have been running it for over 10 years now....quality piece. Here is a link from them on the f350 shafts:
High Angle Drivline-Call Jesse at 530-877-2875 - My Buildup
sulltran is offline
