19.5 or 22.5? - Ford Powerstroke Diesel Forum
Old 02-01-2013, 04:12 AM
19.5 or 22.5?
Trying to decide what ones to put on my 2005 F350, are there pro's and cons to either? I do alot of towing tag and 5th wheel, so will either have an effect on the towing capability or performance?
Old 02-01-2013, 05:12 AM
I always say go big or go home..but when towing u might want the smaller rim so u can have a little more side wall...but I'd take the risk and go big
Old 02-01-2013, 09:27 AM
22.5's might need a lift, could affect towing angles of the 5th wheel. When I hit the lotto I'm going with 19.5 alcoas, only ones Ive founf that dont need 10lug adpater in the style I like.
Just FYI too, 19.5's (the ones I want ) are about $3,000-3,500 with tires and 22.5's are more and tires are just a but more too.
Old 02-01-2013, 10:21 AM
Think I might go pick these up this weekend
22.5 Semi/Truck Wheels***Dually Wheels***
Old 02-02-2013, 05:44 AM
Not bad... Looks good.
Old 02-02-2013, 07:01 AM
19.5 or 22.5?
Do it!!
Sent from AutoGuide.com App
Old 02-02-2013, 07:12 AM
19.5" is all I'd do IMO.
Have you checked to see how it'll affect gearing?
Old 02-02-2013, 12:30 PM
I know it will change the gearing but shouldnt be that bad.
Old 02-02-2013, 05:46 PM
I run 19.5's and love them. I have 225/70 Hercules 902's (14 ply, G load rated)all the way around. If your going to travel off pavement I would suggest a more agressive tread pattern for the rear, like their 702. I chose thes because a friend has a auto repair shop and he runs them on his wreckers and they do very well. As for gearing changes, these are 32.0" tall and that's 1 inch taller than stock. Check your OEM tire size and find out it's diameter for comparison, should be minimal. It really didn't make much of a differance in my 4.10:1 gearing and maybe 2mph with the speedo.
I know price and cost is a big factor for most. I have $1200 bucks in tires and another $1100 in my direct bolt on wheels (all 6, 2 steel, 4 alluminum).
Towing, you can find other posts about the med duty 19.5 tires on this site, but most get close to 100K out of a set towing. I tow two different trailers, 16'/ 6000lbs loaded and 35'/ 15-22000lbs loaded.
And yes I lowered mine, but she still pulls like a champ. I just keep her on the road now.
Old 02-04-2013, 12:56 PM
Not to hijack the thread, but was just on American Force's website and they are now offering 20" dually wheels that are direct bolt on too.(maybe)
The one's I like are here, but still show the adapters in there "cart".
Direct Bolt link
Really opens up the tire options with 20" tires...just make sure they are "E" rate.
Personally I'm going the 19.5" route due to price and more importantly rotating weight.
84lbs more than a factory set vs. 200+ lbs for a 22" or bigger semi wheel set
Set of these @ $1875 (chrome with aluminum inners) ebay dealer
and these recap tires via treadwright:$ 875 shipped
No adapters need, same height as my factory 17" wheel/tire combo too.
