1996 Dually Wheels Question
Hey there,
I am in the process of gathering parts for my dually swap for the truck in my signature. I found some wheels on a local classified site KSL, and was wanting some input on whether or not these wheels would work. I called the lady and she confirmed the dimensions, so they should work, but I will also confirm before purchasing. She said that they were with the truck described in the ad, but not mounted. Below is a link to the wheels. Thank you for your input. Wheels and Tires - SUV/Trucks Classifieds for Utah, Idaho, and Wyoming | ksl.com |
Bump bump.....
Big Jeremy |
Bump for Saturday
Big Jeremy |
They look like 8x6.5" bolt pattern but looks like they are missing the dowl pin hole. Does your axel have a pin?
Sent from my iPhone using Autoguide |
I will be home next weekend and will check the axle.
Big Jeremy |
Those wheels are from a gm correct? I believe that you have to have Ford wheels for your swap because the wheels are hub centric and the gm wheels have a smaller id and would require trimming to fit. Plus the gm wheel uses a different type of lug nut than a Ford Duallt wheel does.
I thank you guys for the replies. But I think I just wait until I find something better or save for new wheels. Besides, I'm not ready to do the swap just yet.
Big Jeremy |
