24.5 Big Truck Wheels - Ford Powerstroke Diesel Forum
Old 06-02-2012, 02:35 AM
I have a set of 24.5 big truck wheels trying to see do I need to have them machined down to a 24 or will they work like they are?
Old 06-02-2012, 04:14 AM
how much lift do you have?
Old 06-02-2012, 06:19 AM
Im actually going to lower it 3/5
Old 06-02-2012, 06:30 AM
Then most likely your going to have to have them shaved in order to run a lower profile tire. There are some killer pics of a white one on here somewhere that did the same as I think your planning. Looks awesome!
Old 06-02-2012, 09:30 AM
What do I have to get milled down?
Old 06-02-2012, 09:37 AM
If your wanting to run a low profile tire you have to get the rims milled to run a 24 inch tire instead of a 24.5 inch semi tire. Tennessee wheel and tire does it I believe, but any good machine shop should be able to do it.
Tennessee Wheel & Tire Semi / Dually Wheels
Old 06-02-2012, 09:46 AM
Do mill the lip down or is it sum else
Old 06-02-2012, 09:54 AM
Idk if I've seen 24.5s yet. Seen 22.5s though.
Old 06-08-2012, 11:08 AM
its not the lip, your lip is already 24. It's more the outside where the fatties hold onto the wheel.
Old 06-09-2012, 04:48 PM
So what has to be done?
