99-04 coil over steering conversion - Ford Powerstroke Diesel Forum
Old 05-19-2012, 01:27 AM
Have anyone converted a 99-04 f350 over to 05 and up front suspension,I know some have but seriously considering it mainly for better turning radius.Was it worth it? Seems the biggest issue is finding a donor truck.please give me your thoughts......
Old 05-22-2012, 01:13 PM
bump........
Old 05-30-2012, 07:07 PM
it is worth it. It will ride much better and if you have all of the parts off of the donor truck it is bolt on. Only thing is that your lug pattern on the front will be different from the rear.
Old 05-31-2012, 03:01 AM
Real Men Love Jesus! <><
Not if you use your front dually spacers and use a srw axle. Its basically the same thing.
Sent from my Acer Android Tablet
Old 05-31-2012, 04:36 AM
So is the front axle from a srw350 different then a dwr 350(width) ?I am asking because if I find and 05 350 thats not a drw but has 410 gears,just wondering if that would work.
Old 05-31-2012, 05:05 AM
Should be the same axle, but with the dually spacer added.
Old 05-31-2012, 05:13 AM
Thanks,now for the hard part finding the parts or a donor truck
Old 06-03-2012, 05:32 PM
So with doing this swap I would have to get the 05-07 wheels to fit the brakes and would have to change the rear diff too?
Old 06-03-2012, 06:58 PM
No, because the spacers that you took off your old axle has the same lug pattern as the wheels. I don't think the brakes are any bigger than the 99-04 models.
Old 06-04-2012, 09:11 AM
Feedback Score: 5 reviews
Brakes are larger..and larger still on the '08 up...if you need help..PM me. we have been doing swaps like this since '08
