how to questions on srw to drw - Ford Powerstroke Diesel Forum
post #1 of 5 Old 05-12-2012, 11:26 AM Thread Starter
Firefighter Member
Shockley6.0's Avatar
Ok like the title says. I have a 03 d80 dually rear end that I'm wanting to convert my 03 srw into a dually. I need some advise on what has to be done. I'm not going to do this probably till around december but i'm wanting to do lots of research before trying this. I'm not an idiot when it comes to this kinda stuff but this is a big project for me but I think with some advice I can do it.
Thanks in advance.
Shockley6.0 is offline
post #2 of 5 Old 05-12-2012, 02:35 PM
Damn, I wish you had a long bed. Oh well. I was considering changing my dually to single.
wick89gt is offline
post #3 of 5 Old 05-12-2012, 02:45 PM
JSchuricht's Avatar
As long as the axle is from a truck that came with a bed ie. not a chassis cab, it will bolt right up. You will need to find a new bed or get some aftermarket fenders like aarowcraft. For the front you will need to find the spacers used on a DRW truck.
JSchuricht is offline
post #4 of 5 Old 05-20-2012, 01:11 PM
And for the obvious is the gear ratio must be the same for front and rear axles if you use the 4x4. Drive shaft will have to be aquired. You can find rear fenders at wrecking yards and can drill the bed to fit them...It should be pretty straight forward
chris1450 is offline
post #5 of 5 Old 06-14-2012, 01:41 AM
f350powerstroke's Avatar
Be nice if u used the 11-12 fenders, if u can get around the gas tank cap.
2007 f-350
SCT Street tune Innovative Diesel
4 inch straight pipe
Bypass coolant filter, ELC
Edge Insight CS
leveled 2.5
130k miles
Infowars.com
REAL TRUCKS DON'T HAVE SPARK PLUGS!
Are U Aware?
f350powerstroke is offline
