on the shifter od light - Ford Powerstroke Diesel Forum
Old 02-13-2012, 01:53 PM
The od button ain't lit and don't do anything when i push it. Anyone have any ideas, maybe a fuse?
Old 02-14-2012, 05:15 PM
The wire that runs through the shifter stalk is likely broken. It's very common for that wire to break - especially if you use the tilt wheel a lot. Do some searching and you'll find a lot of info on how to replace it. Easiest way is to buy the entire shifter stalk - I think I bought mine on eBay, somewhere around $70 if I remember correctly.
