Larger than stock tire wear
I've got a 2000 f350 dually 4x4 that I'm planning to level or lift. I've had the truck for 9 years and it's time for a makeover. I've been reading this forum for a while and think I have a handle on what it's going to take to get what I want. I'll get some 2" spacers from Fred for sure.
I thought 255/86-16 is what I'd get for rubber but there are not a lot of choices out there. I'm thinking of going to 305 or 315's but I'm concerned about the 6" rim width. Main use of the truck is towing a 9500lb jeboat around. For those that have the wide tires how do they wear and what kind of life can I expect out of them? And should I be concerned about having that wide of a tire on such a narrow rim? Thanks. |
If you go much wider than stock you will need spacers for the back. There is a few that run the 315/75/R16 Goodyear Wrangler Duratrac. I've heard they wear very good with 10-12k on them. The centers will wear down a little quicker due to being forced on a 6" rim. IIRC you need to use balancing beads, because standard wheel weights can fly off due to the wide tire/skinny rim. I would prefer them anyways because tire is always perfectly balanced. I was planning on running the 315/75 Duratrac's. They're big enough to get the RPM's down and totally changes the look of the truck. They're also one of the cheaper bigger A/T tires out there at $250 each. I may be going 37s though, because I found out I have 4.30 gears. Probably not because 37s aren't cheap...
Yeah' I'll get 2" spacer's regardless. I've got 4.10's and the 255's shouldn't bother my towing much. I see several guys here that tow more than I do with 35's or more. I've got a chip so I don't think power is an issue and I'd send the chip back to get re-calibrated for the bigger tires.
I guess I'm just a tight-wad and I don't want to buy tires too often. I'm also a little cautious on the wide tires on the narrow rims which I'll likely replace. I'm running Toyo m-55's in the the 235 size now and have about 30K on the fronts and 60k on the rear. This fall it will be time to change them all out. I'm leaning toward the Zone-offroad leveling kit vs a full on lift but I also want a tire that is readily available. Love the truck and it's paid for so no reason to get rid of it. Besides it's not often you see a lifted dually around here and I've always wanted a lifted truck. No more camper or wife so I can do whatever.
Mine has 315s and I love them so far. Truck looks great and they really help on the highway
Sent from my DROIDX using AutoGuide.Com Free |
