Valve Stem? - Ford Powerstroke Diesel Forum
Old 07-05-2011, 02:02 PM
Valve Stem?
With the dually rims are you guys using rubber or steel valve stems?
Old 07-05-2011, 05:29 PM
Powerstroke Techie
Feedback Score: 3 reviews
use whatever is rated for the air pressure you run in your tires. if i recall correctly the rubber stems aren't rated for the tire pressures you'd find in a superduty
