Factory Caps with Spacers?
I am getting ready to order my spacers from Wheeladaptors.com, but I swear that I read somewhere on here that you have to ask for a certain lug nut size. I have been searching high and low, but I cannot find it. Is this true? I really want the factory caps on for a finished look.
Thanks for the help! |
Nothing special here and mine fit . The spacers will come with lugnuts that fit into the spacer for the inner dually wheel . Then you just use the stock lug nuts on the outside . Just give them the year of your truck .
Thanks Bad Night... I figured that was the case, but I figured I better make sure.
Just got my adapters friday from wheeladapters.com. I will be putting them on today. Got the steel ones man are they heavy don't even think my 8 to 10 lug adapters are that heavy.
Sorry for the duimb question .. but are you putting the spacers on the rear wheels? Is that to give it a wider look? Can you space the front as well? Thanks. I have a dually as well and would like to beef it up a little.
I am putting them on the rear because I am going to be putting 285's on the wheels. So to keep them from rubbing each other, gotta put the spacers on.
Got Ya. Thanks for the reply. Nice truck!
Mike , how wide of spacers on the front ? I was thinking about doing this too but was worried about the extra pressure on the bearing assemblies . |
2" make shure you get hubcentric spacers and you will be fine. I have 140k with the spacers with no issues
