Go Back   Ford Powerstroke Diesel Forum > General Topics > General Diesel Discussion > Dually Discussion
Old 11-05-2009, 05:22 PM
panheadjay panheadjay is offline
dually rear width vs srw
what is the width differance between dually rear vs single wheel one tons?
Old 11-05-2009, 06:04 PM
Jake Jake is offline
<-----GTP38R
DRW has a wider axle.
Old 11-05-2009, 06:21 PM
how much wider? thinkin of making my dually srw. i can deal with an inch or two.
Old 11-05-2009, 06:52 PM
<-----GTP38R
On a SRW, the front wheels stick out further than the rear. If you put SRW wheels on a DRW axle, the rears will stick out further than the fronts. Its not much though. Scuffy has a DRW axle under his SRW truck.
Old 11-06-2009, 08:19 AM
dieselcrawler dieselcrawler is offline
Not to hijack, but I have also thought of this... I have often wondered if I could remove the adaptors on the front, and both rear wheels, and just slap on some regular single wheels... just never had the chance to try. With the flat bed I have on my truck at the moment, it's a little too narrow for the dual rear wheels, and single wheels would look good... keep the duals for when I get the utilty bed painted and on the truck. Also opens up the option of larger tires without spacers in the rear... like 35's!!!
Old 11-06-2009, 02:17 PM
looks to me like the front hub adaptor could be removed and bolt on regular wheel. i've seen several dually's with wider wheels on the front as u would use on a srw.
Old 11-08-2009, 06:24 PM
Ten_Bucks Ten_Bucks is offline
Send a message via AIM to Ten_Bucks Send a message via MSN to Ten_Bucks Send a message via Yahoo to Ten_Bucks
DRW rear axle is 72" from wheel flange to wheel flange. SRW axle is 67.5" from wheel flange to wheel flange IIRC.
Scott
Old 11-08-2009, 07:49 PM
thanks. 2,1/4" per side would't be that bad i guess?
Old 11-09-2009, 11:06 AM
Its not bad at all. You can barely notice it. Over on CompD, there are quite a few people that have put a D80 from a DRW F350 into a SRW F350. Just remember when doing the swap to use a D80 from a '99-'04 F350 DRW instead of a '05-up. The '99-'04 rearend still has the 8x170mm bolt pattern on the hubs whereas the '05-up rearend has a different pattern. 8x200mm IIRC.
Scott
Old 11-09-2009, 06:32 PM
<-----GTP38R
Bolt patterns are the same.
