Go Back   Ford Powerstroke Diesel Forum > General Topics > General Diesel Discussion > Dually Discussion
Old 09-15-2009, 04:47 PM
JER-1 JER-1 is offline
Cool 4.10 GEARS TO 3.73 OR 3.54
Any opinons if I take my 4.10 to 3.73 or 3.54 gears have to change front and back pain but lower rpms I hope would much increase mpg.???
Anyone know of a 2 speed rear end for this 2005 f-350 dully maybe have the 4.10 for towing and 3.73 or 3.54 gears for everday drivin.???
Jer-1
Old 09-18-2009, 02:20 PM
Quickerthanu Quickerthanu is offline
Jer-1
A 2 speed rear gear would be awesome!!....but I have never heard of such a beast for a truck this small.
I do know that gearvendors sells a double OD option.....but don't think it will work on our 4x4's tho.
GearVendors
Old 09-26-2009, 08:25 PM
BennyLumpkin BennyLumpkin is offline
Send a message via AIM to BennyLumpkin
you can make the gearvendors OD work...you just cant run it in 4 wheel.....either way it just goes behind your trans, or in this case the transfer case.
Old 09-26-2009, 08:33 PM
TurboSevenThree TurboSevenThree is offline
I miss the 90's. =[
Jer-1
you're a freakin genius. Patent it!
Old 10-21-2009, 10:37 AM
chipster chipster is offline
fixing to drop some 3.73 in my 99... i will let you know how it turns out. There is already a pretty good discussion for the same subject lower down the page on 7.3 drivetrain section. Got me some Yukon 3.73 gears for 350 bucks. I have heard of people doing 3.73 in rear and leaving 4.10 in front. just make sure you dont run it on hard surface like that.
Old 10-21-2009, 10:52 AM
cowboyf250 cowboyf250 is offline
you shouldnt run two diff. gears in a 4wd. it will **** up the transfer case
