Rear axle yoke snapped in half. Will a 10.25 pinion yoke work on a 10.5?
I've got a '99 F350, rear pinion yoke snapped off last night. Need to replace it, going to hit the junkyard, but need to know if a older 10.25 yoke will work.
Thanks! |
Here's what it looks like now....
Wow, that's different. Do you think the U-Joint was bad or was it just one of those things that happen? I don't know whether an older one will work or not, so here is a free
![]() -Aaron |
I think it will work. Pull the yoke and take it with you.
Thank you squidbilly
What were you doing when it snapped? :burnout
Let someone borrow it. Guess they got alittle happy.
Depends on how old of one you get there are many different ones, somewhere in the early 90's they had a short pinion version, and switched to a long oinion version, early also had 1330 or 1350 series U-joints, Newer versions had 1350 or 1410 series U-joints.
The splines are the same as long as it is for a long pinion yoke 1993'ish or newer. Just take a tape measure and make sure it is the same width as your old one to make sure its the right one. |
