driveline vibration under acceleration above 60 - Ford Powerstroke Diesel Forum
post #1 of 8 Old 06-16-2014, 04:09 PM Thread Starter
ok here we go i have seen may posts about vibration but this 1 is kicking my a$$ new ujoints new carrier bearing also shimmed for the lift everthing looks and feels great but at 60 mph under accel there is a vibration in the seat and accelerator pedal that increases with speed not rpm *** soon as you lift off the go pedal vibrations gone its possible the shaft just needs balancing but not sure this is my second 6.0 and did not have this vibration in my 04 with twice the miles on it( please help !)
soot life is offline
post #2 of 8 Old 06-16-2014, 04:23 PM
jse51599's Avatar
I put new exhaust on mine, and didn't notice it was touching the trans cross member. The vibrations didn't really get noticeable until highway speeds; the faster I went, the worse it got. It felt like it was coming from under my seat. I would describe it as a metal to metal contact (obviously)..... hope this helps.
6637, Diamond Eye Turbo Back, Riffraff Billet Intake Plenums and Intercooler Boots, WW2, Deleted EBPV
305 70 16 Toyo A/T IIs
Jim
jse51599 is offline
post #3 of 8 Old 06-16-2014, 04:28 PM
jjvizinat's Avatar
Had the same exact problem. Took me forever to figure it out. Once I finally did that bolt on the crossbar almost burned thru my exhaust. Mine was in low rpm ranges though
2006 F-250 King Ranch
Headstuds, OEM gaskets, Updated Oil Cooler, Stand Pipes, Dummy Plugs, STC Fitting (Trucks Unlimited, NC)
35" Toyo Open Country M/T
Coolant Filter with ELC Coolant
Blue Fuel Spring Upgrade
S&B Cold Air Intake
EGR Delete
SCT X4
Nice and clean
jjvizinat is offline
post #4 of 8 Old 06-16-2014, 04:30 PM Thread Starter
thats the first thing i checked i have mbrp turbo back system and its clear all the way back thats why this is been such a pain
post #5 of 8 Old 06-17-2014, 02:39 AM
jse51599's Avatar
How many miles are on your truck?
Jim
jse51599 is offline
post #6 of 8 Old 06-17-2014, 04:37 AM
sbluke55's Avatar
Quoted: 622 Post(s)
Garage
What size of lift? Cab and bed configuration?
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is offline
post #7 of 8 Old 06-17-2014, 05:26 AM
Heavy_GD's Avatar
Quoted: 1721 Post(s)
Feedback Score: 3 reviews
you lost me:
increases with speed not rpm as soon as you lift off the go pedal vibrations gone
if it increases with speed, then when you lift off the pedal you are going the same speed... did you have that comment backwards?
GD
Originally Posted by Patriot View Post
...because Patriot.
Heavy_GD is offline
post #8 of 8 Old 08-19-2014, 10:25 AM
BigEZ's Avatar
Holy smokes. I've been chasing a similar issue myself. I noticed there is some slop in my exhaust after the cat delete, though it is properly mounted in all the hangers. At freeway speed I feel what can only be described as a thumping tap (not heavy, very light) that I feel through my left foot on the floor. I've checked the U joints and the drive shaft thinking it was there. For me the same thing, when I let off the gas it goes away until I get back to just cruising at freeway speed. I started to think it was the transmission since it only seems to happen in overdrive.
I will check the exhaust to see if it is hitting as well. Would take a HUGE load off my mind. I was waiting for my driveshaft to bounce off on a dark highway at night in the raging thunderstorm.
2003 F350 6.0 PSCC XLT Long Bed, Cat delete, MBRP 4", high idle mod, Rotella T6, Edge Insight CTS
BigEZ is offline
