Help for the love of god - Ford Powerstroke Diesel Forum
post #1 of 7 Old 06-06-2014, 05:23 AM Thread Starter
This trucks driving me insane
1999.5 7.3 ext cab short bed 4x4 (no front abs)
In the past month ive done new brakes, calipers, pads, front shocks and replaced the drivers side wheel bearing and u joint, also put a rough country stabilizer on the front.. things have improved but since i bought the truck ive always heard this faint rattle from the front end when hitting bumps.. its almost like the sound of a loose bracket bouncing around.. i cant pin point where its coming from, its driving me absolutely insane.. i cant tell if its a serious problem or just something to disregard..
can anyone pleeeeeeease recommend things that come loose that i should inspect?? or things to tighten.. im going to be under there tomorrow tightening every bolt i see.. can there be something loose in my passenger wheel?
Thanks ahead, im down 1000$ in parts already
awdtsi98 is offline
post #2 of 7 Old 06-06-2014, 05:32 AM
sbluke55's Avatar
Quoted: 590 Post(s)
Garage
Check sway bar and sway bar end links.
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is offline
post #3 of 7 Old 06-06-2014, 07:42 AM Thread Starter
everyone keeps saying that, so i guess thats what ill check lol
awdtsi98 is offline
post #4 of 7 Old 06-06-2014, 07:50 AM
Vannnce's Avatar
Quoted: 13 Post(s)
is your exhaust hitting anything anywhere, or real close to anything? thatll cause a rattle if its up front by the down pipe
-Vance-
.2002 f350 Lariat 4" lift w/ 35's. Hydra w/PHP. Swamps 175/146 injectors. gauges. banks power elbow, 4" dp 5"out,RiffRaffs FRX ww, ccv, AIH delete riff raff boost port, '10 tailgate mod amongst a bunch of other goods
.B&W turnover/ companion to haul my 2001 Prowler 5'ver. Home away from home
I.B.E.W. Local 1002
Vannnce is offline
post #5 of 7 Old 06-06-2014, 08:24 PM
blue99stroker's Avatar
Quoted: 283 Post(s)
My dads exhaust was rubbing right in the middle of the can.
Drag link clunk?
Wheel bearings, hubs, leaf spring bushings and everything else they mentioned
blue99stroker is offline
post #6 of 7 Old 06-07-2014, 10:19 PM
Quoted: 3 Post(s)
A loose track bar will make noise at the bracket when hitting bumps.
11 F250 CCSB King Ranch
Tyrant tunes, No Limit Stage 2, No Limit Block Off, 5" exhaust, CTS
2.5" Carli Commuter, 4.5" PMF block, 37x12.5R20 Toyo RTs, Stock wheels
01 Ex 7.3l Limited
Swamps tunes, 6637, 4" exhaust, 6.0 trans cooler, Hellwig rear swaybar, CTS
06 headlights
bigred3297 is offline
post #7 of 7 Old 07-29-2014, 07:25 AM Thread Starter
it ended up being my superwinch hubs.. which baffles me.. they are brand new, but with them removed the rattles gone.. idk anymore about to sell the truck, im running out of patience for this stuff
awdtsi98 is offline
