Rear axle wheel bearings - Ford Powerstroke Diesel Forum
post #1 of 3 Old 02-27-2014, 12:59 PM Thread Starter
Hey guys had to swap out the parking brake so the hubs and bearings all had to come out i was just wondering if packing them with bearing grease would be a problem it appears that they are lubed by the dif fluid and i packed them with grease and put everything back together before sparing it a second thought but I'd like to know if it all needs to come apart again before i replace the rear dif fluid or if i can just leave the grease on there
steve349 is offline
post #2 of 3 Old 05-29-2014, 07:06 PM
Jon_001's Avatar
What kind of grease? i.e. brand and temp rating as well as your best description of the texture. If it doesn't have any graphite in it you are probably fine. My best recommendation is for you to compare your grease ingredients to that of engine assembly lube. If they are close don't worry about it.
Jon_001 is offline
post #3 of 3 Old 05-29-2014, 07:17 PM
ZMANN's Avatar
Quoted: 1673 Post(s)
well it's been 3 months so I hope he got it figured LOL
We Miss you Ronnie
ZMANN is online now
