Shaking bad! inoperable! 96 f350 - Ford Powerstroke Diesel Forum
Old 08-28-2008, 04:22 PM
i cant even drive it it shakes so bad!
Really Bad Shake
Old 08-28-2008, 04:23 PM
ADMIN AND TECH
tracking bar needs replacing
Old 08-28-2008, 04:24 PM
whats the tracking bar? would this cause the shake?
Old 08-28-2008, 04:29 PM
ADMIN AND TECH
yes it will cause the shake , its the bar that runs from the frame down to the front diff , there are bushings on each end that wear out , replace it , problem solved
Old 08-28-2008, 04:30 PM
so its not the steering links and bushings?
Old 08-28-2008, 04:32 PM
ADMIN AND TECH
those other parts will not cause what i call the death shake
Old 08-28-2008, 04:35 PM
duct tape & zip ties
But they maybe worn out and need replacing.
Old 08-28-2008, 04:37 PM
it is a death shake.... ill get a friend to move the wheel and i watch....
Looks like its a trip to pick n pull or RNR dismantlers.....
Old 08-28-2008, 04:46 PM
Do not get used parts to fix this problem. As you may end up wasting money. I strongly suggest you replace these worn out parts with only new parts.
Old 08-28-2008, 05:01 PM
Maybe U-Joints?
