Universal Joint Removal - Ford Powerstroke Diesel Forum
Old 08-17-2008, 08:02 AM
Does anyone know how to remove the universal joint that connects the outer shaft to the axle shaft? There is no "c" clip, there is a cover of some type....
Old 09-22-2008, 01:05 PM
I would like to know also
Old 09-22-2008, 01:49 PM
Going to tackle this weekend. C-clips are on the inside of the yoke not the outside like the rest of the driveline. I'm using NAPA Performer U-Joints Part #374. Here are good instructionsBall Joint Replacement Write-Up For 2000 Ford F250 Superduty
Old 09-22-2008, 06:55 PM
I hate to say this, but I found "c" clips on the inside of the joint. I removed them and beat the crap out of them with the fractured piece of axle until I noticed them moving. Once, I was able to understand how to get them out, it was a matter of using "man-force" to replace them.
Old 09-22-2008, 06:59 PM
I just read the posting and I apoligize for how pitiful it sounds. I removed the clips with a screwdriver, then set the axle assembly in a vice. Using that broke peice of axle shaft as a driver, I pounded the U-joint cap straight down until I came free; then repeated it with the other three caps....installed in reverse order. I hope this sounds better, I'm sorry for that previous posting.
Old 09-24-2008, 05:49 PM
Glad you got them out. They are a pain to hammer out by hand.
Old 02-07-2009, 05:23 PM
what size of socket do I need to take the rotor off 25/8 maybe ?
Old 02-08-2009, 05:58 AM
What year/mdl truck?
Are removing the front rotor?
2WD or 4 WD?
My '02 F350 4X4 uses no socket..
