transmission fan? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 09-02-2013, 04:39 PM Thread Starter
transmission fan?
I have a 2006 F250 6.0. Towed trailer yesterday and after dropping off trailer trans is making loud noise like the fan is still own. Even though not in tow/haul mode and not towing. Trans is shifting fine, and all guages are normal. Any suggestions
3030Bass is offline
post #2 of 5 Old 09-02-2013, 04:46 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
Your kinda confusing me. If your truck is stock you don't have a transmission fan. So is the fan for the radiator on? Or are you saying the transmission is making a fan type noise?
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #3 of 5 Old 09-02-2013, 05:05 PM Thread Starter
It is stock. The noise is the same noise that the trans makes when in tow haul mode when under a load. I have not had the same noise occur during normal driving.
3030Bass is offline
post #4 of 5 Old 09-02-2013, 05:19 PM
jesilvas's Avatar
Quoted: 3 Post(s)
The trans makes a different noise in tow/haul than in regular? Never heard that one before.
You sure it's not your engine fan still running sometimes?
4R100, 2wd
330,000 + miles
jesilvas is offline
post #5 of 5 Old 09-02-2013, 06:42 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
If I understand the tow/haul mode it does not change anything in the transmission itself. It only changes the shift points. So Id say if you are getting a strange noise while towing or under a load you got issue's.
Forget the dummy gauges, they are worthless...go get a monitor. I got a feeling your truck is hiding a secret......
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
