Drivers side d50 ttb help - Ford Powerstroke Diesel Forum
post #1 of 1 Old 04-18-2013, 12:41 PM Thread Starter
All, I have a 97 F250 extended cab 4x4. I am looking for the complete hub assembly for my truck. Everywhere I look, it seems that all the parts for the 97 are under 8500 GVW parts for the new body style. I cant even find a hub assembly for a 95 or 96. The Ford Stealership wants the axle tag which is no longer there. I have a D50 TTB setup on leaf springs for the front axle. Does anyone have a part number or know what I need to order so that I can get my baby back on the road? This all started with a bad ball joint and a grenaded auto locking hub :/ BTW, i have the 7.3 turbo in it.
There are two pieces that I need. The inner spindle bearing assembly that the axle shaft goes through and the outer hub assembly that the locking hubs go into and the rotor mounts to. I was able to save the steering knuckle and the rotor.
Thanks in advance.
PS. I cant afford to toss a Dana 60 solid axle under the truck. So, that is not an option at this time. In the future, I plan to do the swap.
d4klutz is offline
