Brake caliper locking up - Ford Powerstroke Diesel Forum
post #1 of 6 Old 04-17-2013, 01:51 PM Thread Starter
2003 f250 4x4. Year and a half ago I replaced both front rotors, pads and the driver side caliper. I drove it for about 6 months with no issues. Tranny went out and the truck sat for about 8 months. New tranny and Im back on the road.
However the driverside brake began dragging, pulling hard to the left, smell of burning brakes. I pulled the caliper, cleaned the pins the caliper rides on, regreased and put back together. Did right side too. Worked good for about 200 miles now today under normal driving conditions it locked up again and was smoking so much when i got it home i thought it was going to catch fire.
What is the problem?
8" Skyjacker lift
2" wheel spacers
22" American Racing rims
40x15.5x22 M16's
DIY intake
Zoodad Mod
4" strait exaust
Glowshift gauges
DIY Boost Fooler
Unplugged wastegate
TS 6 position chip
dr8082 is offline
post #2 of 6 Old 04-17-2013, 03:03 PM
Quoted: 133 Post(s)
Feedback Score: 3 reviews
Take the caliper off and push each piston, one at a time in a bit (C-clamp works well). I'll bet you find one of them binding in the bore. This often is the result of contaminated brake fluid (it's hydroscopic and, when old, has enough water in it to cause the bore to form rust). If it's sticking, replace the caliper (they're cheap enough to prevent Me from rebuilding them...) and flush the entire brake system with new fluid.
NoRalPh is offline
post #3 of 6 Old 04-17-2013, 03:07 PM Thread Starter
Thanks man, what all is involved in a brake flush. Im going to pick up two new calipers and the brake fluid and get this done. Someone told me it could also be a bad brake line/hose....what do you think. I may replace those also.
8" Skyjacker lift
2" wheel spacers
40x15.5x22 M16's
DIY intake
Zoodad Mod
4" strait exaust
Glowshift gauges
DIY Boost Fooler
Unplugged wastegate
TS 6 position chip
dr8082 is offline
post #4 of 6 Old 04-17-2013, 05:02 PM
Quoted: 133 Post(s)
A hose can deteriorate and, inside, a flap forms that creates a kind of check-valve. That's hard to diagnose though, it's one of those, "nothing else it could be" kinda things after you've checked everything else
That's why I say confirm the pistons aren't binding, it's something you can check...
I have a cheap pressure bleeder I flush with, you can do it, with a helper, by doing the ole "Pump it up - Hold it Down" method. Start with the longest line and work to the shortest. Buy a couple of quarts and flush all the old stuff out.
NoRalPh is offline
post #5 of 6 Old 04-18-2013, 02:38 AM Thread Starter
Gotcha, just bleed em till they run clean basicly. Im going to check lines they cant be that much.
Thanks for your help.
8" Skyjacker lift
2" wheel spacers
40x15.5x22 M16's
DIY intake
Zoodad Mod
4" strait exaust
Glowshift gauges
DIY Boost Fooler
Unplugged wastegate
TS 6 position chip
dr8082 is offline
post #6 of 6 Old 04-21-2013, 04:51 PM Thread Starter
To complete this thread for those in the future. One piston in the new caliper was seized. Caliper was only a year or so old. Carquest replaced it as defective for no charge.
8" Skyjacker lift
2" wheel spacers
40x15.5x22 M16's
DIY intake
Zoodad Mod
4" strait exaust
Glowshift gauges
DIY Boost Fooler
Unplugged wastegate
TS 6 position chip
dr8082 is offline
