04 Rearend Fluid - Ford Powerstroke Diesel Forum
post #1 of 5 Old 03-06-2013, 03:42 AM Thread Starter
04 Rearend Fluid
Hi all. I have a 04 SD with LS and it recently hit 100K miles. I wanted to change the fluid in it but I keep hearing I need to add friction modifier to the oil. I've been reading up on it and some people say not to add it unless you need it. I was going to use either Mobil1 or Motorcraft 75w-140 for the change. Thank you in advance for your opinions and help!
-Dan
Ford625 is offline
post #2 of 5 Old 03-06-2013, 04:45 AM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 20 Post(s)
You have to add it unless the oil you use already has an additive in it.
dhanna6powerstroke is offline
post #3 of 5 Old 03-06-2013, 09:16 AM Thread Starter
I haven't bought the oil yet. Which ones have it in it? Thanks!
Ford625 is offline
post #4 of 5 Old 03-06-2013, 09:20 AM
Mod Newbie
Quoted: 20 Post(s)
Motorcraft doesn't because you have to buy the friction modifier separate. I think Royal Purple does and Valvoline has a synthetic gear oil that does. It should say in the bottle if it already has additives.
post #5 of 5 Old 03-06-2013, 03:17 PM Thread Starter
Alright great! Thanks for the help!
Ford625 is offline
